Question about HP L1702 17" LCD Monitor
HP 1702 won't power up
I need to find where i can purchase the following capacitors:
100uf 6v
1000uf 25v
470uf 16v
this is for HP 1702 LCD monitor.
thanks, Frank
  • Anonymous Nov 21, 2008
    q803 duf
  • 61 Answers
Http://mcmelectronics.com/browse/Capacitors/3829501
Posted on Sep 21, 2008
Polaroid flat screen without picture/sound/indicator light--only chirping noise
The problem could be in the inverter board located near the display.
Jul 31, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Philips 20ps47s301 turns on then starts clicking and turns off
IT SOUNDS LIKE YOU HAVE A POWER SUPPLY PROBLEM OR RELAY PROBLEM. BEING A 20 INCH SET IT IS NOT WORTH REPIRING. PARTS AND LABOR WILL BE OVER $100.
Jan 16, 2009 | Philips 20PS40S 20" TV
When i switch on my P.C. and my FP 5313 screen it flickers
This is a known problem with a series of components inside the monitor. There are about 11 capacitors that if replaced will allow the monitor to function properly.
The best place to go to read more is http://www.badcaps.net/forum/printthread.php?t=2658
The list of the capacitors that are bad are below with possible replacements.
C922, C925: Hermei LE 1000uF 16V, low impedance, general purpose, replacing with 1000uF 16V Samxon GF.
C201: Hermei LZ 150uF 25V, ultra low impedance, high ripple current, replacing with 1000uF 25V Samxon GF.
C924, C926, C929, C930, C932, C933: Hermei LT 470uF 16V, high ripple current, low impedance, replacing with 1000uF 16V Samxon GF.
C207: Unknown CD110 50uF 4.7uF (general purpose), replacing with a 35V 4.7uF tantalum unit (SCP/Short Circuit Protection pin on TL1451 won't get anywhere near 35V).
C907: WC (with stylized Westinghouse W) SM 22uF 50V (general purpose), replacing with 63V 100uF Samxon GF (used for SMPS controller Vcc filtering).
C905: Hermei HT 100uF 400V, standard, general purpose, leaving as is - generally no problem.
Dec 06, 2008 | HP Compaq FP5315 15" LCD Monitor
HP pavilion VF15 moitor
Replace 4 dead 470uf 16v capacitors and 1 1000uf 16v capacitor on power in circuit board. worked for me.
Oct 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Black screen
Does your computer appear to be booting?
Do you head any startup noises, or the startup sounds you hear when Windows loads?
In no, have your computer checked.
If yes, make sure your cables are all snug. Other than that, it depends on how into "fixing it yourself" you are.
Give this a try:
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad. Check the area for any cracked or overheated ceramic or mylar capacitors.
You'll need a soldering iron, solder, solder ****** and some idea of how soldering and desoldering work.
Mar 27, 2008 | Gateway FPD2275W LCD Monitor
Digital mode of VX2035wm has stopped working
I recognize the model number as a Viewsonic model.
Check the digital input using another computer to make sure it's the monitor.
If you're brave enough, do this:
Capacitors are used to remove ripple from the switching power supply. This ripple, or noise could cause digital circuits to act up. Usually it's easy to spot the bad ones. Good ones look like a perfect cylinder. If they look swollen on the top they are likely bad.
If you do this and it does not solve the problem, the main board could be going bad and require replacement, You should be able to order one from your local Viewsonic service shop. By the way, that model is fairly new. Remember that Viewsonic monitors carry a three year warranty.
Mar 24, 2008 | Gateway FPD2275W LCD Monitor
Viewsonic lcd problem
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
The most possible causes are bad capacitors or a bad semi-conductor.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad and can cause the power to cycle up and down. Check the area for any cracked or overheated ceramic or mylar capacitors.
Don’t forget to check for caps on the main board. Some times these boards are overly simple and only have a couple of caps, but other times they are teaming with them.
Jan 06, 2008 | ViewSonic VX924 19" LCD Monitor
Veiwsonic 924x
Dec 27, 2007 | ViewSonic VX924 19" LCD Monitor
All lights work but powers on and off.
Dec 10, 2007 | ViewSonic VX924 19" LCD Monitor
Acer AL2021
I fixed my AL2021 by replacing the output caps on the power board. $4 repair. Pull the thing apart and replace the 1000uF, 680uF and 470uF caps on the end of the power board.
Jul 10, 2006 | Acer AL2032WD 20" Flat Panel LCD Monitor
HP L1702 17" LCD Monitor Logo
718 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
