Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Twin thin dryer
Dryer not hot. Bought used, washer works fine, dryer spins well, but no heat. i dont have a manual so i need to know what to check. Is pilot auto,
  • NICKJR004 Sep 25, 2008
    SAME EXACT PROBLEM
  • vem1203 Dec 14, 2008
    My dryer does not get hot. What is the problem
I believe that it is the thermostat that is bad if it will not heat. It is the piece that supplys electrical heat to the heat coils. 696818 is the whirlpool part number for the thermostat on my stackable unit and it can be purchased online for 10-15 bucks.
Posted on Jan 02, 2009
The reason my dryer was not heating up is the thermal cutoff was bad. The part is not expensive however you need a repair man to replace it.
Posted on Oct 05, 2008
  • 750 Answers
Hello Xcfd
Welcome to Fixya
You can also try unplugging the dryer for 5 minutes and see if the dryer resets!
Clothes are not drying satisfactorily
Try the following
Is the lint screen clogged with lint?
Is the exhaust vent or outside exhaust hood clogged with lint,
restricting air movement? Run the dryer for 5-10 minutes.
Hold your hand under the outside exhaust hood to check air
movement. If you do not feel air movement, clean exhaust
system of lint or replace exhaust vent with heavy metal or
flexible metal vent. See your Installation Instructions.
Is the exhaust vent crushed or kinked? Replace with heavy
metal or flexible metal vent. See your Installation Instructions.
Has a fuse blown, or a circuit breaker tripped? Electric dryers
use 2 household fuses or breakers. The drum may be turning
but you may not have heat.
Has an air dry cycle been selected? Select the right cycle for
the types of garments being dried. See “Drying, Cycle and
Temperature Tips.”
For gas dryers, is the valve open on the supply line?
Are fabric softener sheets blocking the grille? Use only one
fabric softener sheet and only use it once.
n Is the dryer located in a room with temperature below
45ºF (7ºC)?
Proper operation of dryer cycles requires temperatures above
45ºF (7ºC).
n Was a cold rinse water used? Was the load very wet?
Expect longer drying times with items rinsed in cold water
and with items that hold moisture (cottons).
n Is the load too large and heavy to dry quickly?
Separate the load to tumble freely.
This is the location of the whirlpool user manual you asked for!
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-
%203406876.pdf
Please remember to leave a rating before you leave.
Thank You
Posted on Oct 03, 2008
What should we do? Our Whirlpool Thin Twin dryer doesn't get hot anymore.
You can fix it,, Here is an easy test and I can give you a definite answer on your problem and solution
open your dryer door, on the door you should see a little peg or clip sticking out which pushes into a corresponding hole in the on the front of the dryer. That's the kill switch for the dryer , it will click when you push it in, hold that in and turn your dryer on its highest setting.
Then look in your dryer while it's running , inside in the back you will see a lot of holes or slats in which the heating element pushes the heat through. You should see a slight glow and feel heat from those holes/vents, if not then I'm saying your element is out. You can normally order one through your local hardware/ appliance store using the dryers model number. For anywhere from ($20-$50)
Apr 29, 2014 | Whirlpool Dryers
Thin Twin will not spin!
best left to a qualified service person
Jan 25, 2014 | Washing Machines
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Mar 18, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool thin twin problem
First be sure you're getting power to the motor this could cause both problems. If getting power then
sounds like you have 2 problems.
Dryer
On the heating problem be sure you have 220 volts at the power block, check the heating element , thermostats & high temp cutoff with an ohmmeter. Also check the centrifical switch on the motor it keeps the heat off for safety till the motor is up to speed so the fan is working.
Washer
Check lid switch some machines won't do anything but fill with the lid open . To check lid switch push the the switch down with a small screwdriver. If switch is ok check the coupler between the motor & transmission it can cause no agitate or spin. If all these are ok you may have a transmission problem. Last resort may be timer or wireing.
Nov 20, 2017 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
449 people viewed this question
Dan Webster
Dan Webster
Sal De
