Question about Dryers
I want to know what the conair curl dazzler 1250 is my dad brought it for me and dont i know what it is!!
I was cleaning the lint catcher while the dryer was on and dropped a washcloth into it. How do I get the washcloth out?
first unplug the unit then remove lint trap then try a stiff wire with a slight curl hook on the end a hanger will do its a smooth chamber push it till it hits it or tuches the bottom twist the wire pull it should come out,if this dont work u half to pull the back of and pull the dryer vent filter tube off with screws at the bottom and it should be there..
Apr 09, 2011 | Estate Dryers
I just installed my lgr4634jq0gas dryer given from dad to me it worked like new for him ,i cant get it to ignite ..suggestions greatly appeciated..
If it took a bounce on the way from Dad's, the ignitor probably got a hairline crack in it. Replace that tired, old, brittle, ignitor.
Jul 09, 2009 | Whirlpool LGR5636L Gas Dryer
Maytag dryer model HYE3657AYW
I assume that your u.s. dryer is the standard 220 volt, and your question is what is the voltage in Mexico where your father resides. Most places in Mexico will have the 220 volt supply available. This should be easily found out with any cheap 15.00 meter. If the receptacle accepts the dryers plug, it is more than likely the proper voltage.
( Maybe your father is really wanting to save energy and realizes that his clothes will last forever when they are hung up to dry! )
Mar 04, 2009 | Maytag Neptune MCE8000AY Electric Dryer
No heat to dryer
it mean it dont have a gas pilot and it has a ignitor instead ,,,, if you turn on the dryer and dont see a glow then it may have a bad ignitor ,,, on a kenmore it should not have a door to open unless it is a old unit and the newer ones has a peep hole to see into.
Dec 04, 2008 | Kenmore 72602 Gas Dryer
Heating Element
your dryer is a 220 plug check the circuit breaker first
one 110 runs the heating element and the other 110 runs motor and dials
this is usually the cause of dryer malfunctions
heating elements are simple big mesh of curled metal wire like a toaster but more of it
it would take alot to knock out the heating element
check the dials too these could be sticking or worn dials you dont have to run dryer to check dials
Jun 27, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not drying clothes
Jun 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Frizzy hair!! help with conair hair dryer!!!
http://www.naturallycurly.com/
ask the curlies on the forums here! HTH!
Mar 07, 2008 | Dryers
Lint Blows Out the Top!
it should be curled but not kinked.make sure air is blowing outside with force.also make sure to pull dryer good distance away from wall.
Apr 05, 2007 | Whirlpool LEQ9858P Electric Dryer
You have a bad clog in your ducting.
Apr 05, 2007 | Whirlpool LEQ9858L Electric Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
