Question about Whirlpool Dryers
Whirlpool Dryer LET7848A - no HIGH heat
My Whirlpool Dryer model LET7848A works fine, except it has no heat when on HIGH setting. Low and Medium work fine. I'm thinking a bad switch or broken wire, maybe. Any ideas?
  • 5 more comments
  • civilian Sep 21, 2008
    Update: I have the dryer open. No obvious bad connections. Lint exhaust path not blocked. Heating element has continuity. Temerature selector switch gives three different resistance readings (High=infinity, Med=approx 500 ohms, Low=approx 5500 ohms). Tested three breakers, all had continuity. What now?
    Solution #1 did not solve this. I disassembled and inspected the heating coils. No breaks or shorts. Electrical continuity close to zero ohms. I'm beginning to think the problem is in the control circuit board.
    Still seeking a solution. I have tested the breakers, the heat select switch, and the heating coils. Any more suggestions?
    Scott Ellin's solution ("..submit a warranty claim...") did not help at all. Is there anyone out there that actually knows something about dryers?
  • civilian Sep 22, 2008
    I keep receiving lame suggestions that mean nothing. The last one was "try to use the tester to check the wire if it is ok
    or check the switch or replaced the switch." What does that even mean? If anyone out there can actually write a proper English sentence, please help. Others, please refrain from commenting. Thanks.
  • civilian Sep 23, 2008
    I have received nothing but ridiculous advice. The lat one was "u have to go with a washing mashine repair." How does this help me? If I wanted to have someone else fix this, I would not use this forum. Please, if you don't have anything helpful to say, don't comment!
  • civilian Sep 24, 2008
    This seems like a reasonable solution. I will try this and see if it helps.
    President:
  • 1,263 Answers
Have a solid state resistor for each heat setting you have a infinite ohm setting on high this tells the main board that you have an overload and therefore your high setting will not work. it's obvious that you know how to solder on a circuit board so just replace the resistor on the high temp path. your values are in increments of 10 so your high setting should register 50 ohms of resistance. this should solve the problem. please rate the solution........thanks
Posted on Sep 23, 2008
  • 535 Answers
U have to go with a washing mashine repair
or visit
www.repairclinic.com
Posted on Sep 22, 2008
    President:
  • 1,952 Answers
Check the thermal fuse on top of the heater housing, make sure you take 1 wire off of it, and check it on ohms..else change ur fuse
  • mohammed marika thambi
    mohammed marika thambi Sep 22, 2008
    The moisture sensor's second wire(if necessary) is provided I would assume
    by it being grounded to the chassis. A common problem with this dryer is
    the moisture sensor becoming covered with a waxy substance from the use of
    dryer sheets. It then doesn't sense the moisture in the clothes and the
    dryer goes into cool down phase. Cleaning off with alcohol solves that
    problem. I would think you could check it by checking for continuity
    between the sensor surface and that wire . Otherwise, I would be suspicious
    of one of the thermostats...the fact that it is getting some heat rules out
    the white sealed fuse..when that goes the burner won't come on at all.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!!
Posted on Sep 21, 2008
    Guru:
  • 558 Answers
Thanks for your posting in FixYa.
Please do the following:
If it is under warranty then go for replace it immediately.
Hope this would help you a lot.
Dont forget to rank me up. Have a nice day.
Best of Luck & Regards
ELLIN
  • Puneet Jain
    Puneet Jain Sep 23, 2008
    Thanks for your reply.
    I think this part you need to replace:
    Heating element thermal cut-off (thermal fuse) 360 degrees and high-limit thermostat 250 degrees.
    It will cost upto $28. Let me know if it fix the problem.
    Have a nice day.
    Best of Luck
    & Regards
    ELLIN
    Sergeant:
  • 399 Answers
Yes the coils which heat the heater heating plates are faulty because of broken wire.
they hshould be replaced to make it work.
thanks.
How do I turn the heat eating down?
Need a make / model of the dryer your asking about. There are far to many out on the market. They work differently. But usually the settings are Regular is high heat easy care is medium heat. And delicates is a low setting for heat.And fluff is No heat.
Sep 30, 2014 | Dryers
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Kennmore Elite HE4 no heat on low or extra-low setting
Assuming this is a gas dryer, it is likely the igniter has failed. The igniter plate has to heat up to glowing in order to heat up the thermocouple that turns on the gas valve.
Sep 03, 2012 | Kenmore Dryers
Two problems with Whirlpool Dryer
I would suspect the heating element. I bet you are asking why this clown is saying that when you already told him that on high heat it worked fine. SIMPLE! Your heating element is made up of five coils. For low heat your dryer uses two heating elements and for high all five. So if one or two of the heating elements are open and they happen to be the low temp dry setting ones, that would explain it. That model doesn't have the dryness sensor on it (according to my documentation) so the heating element is the most likely cause.
Hope this helps!
ImJustAvg aka Hal
Dec 30, 2011 | Whirlpool Dryers
Our Whirlpool dryer GGQ8831 dries too hot, even on the extra low setting. I do not use the sensor to dry clothes anymore, either. We don't know if it's due to the ductwork (possible inadequate air flow) or...
You most likely need to replace the cycling thermostat located on you duct inside the dryer. If you continue to use like it is, the high limit will end up going out. When it does the dryer will stop working al together. There are two that you need. If you go to parts select.com. enter your model #. It will bring you unit up. Click on Bulkhead parts picture on right. you will need part number 42 and 43. These are cycling thermostats. One is a lower heat and the other is the medium and high heat. what you running on at this time is the thermal cut off. When is goes bad it will put the thermal fuse out, cutting the whole machine off. I hope this helps. No to worry, these are common parts that go out from time to time.
Oct 10, 2009 | Whirlpool Dryers
My whirlpool imperial model number LER8858eq1 has stopped heating. this first happened when the dryer was set to high, and now the dryer will not heat on medium as well. The dryer is 11 years old. Any...
FIX IT!!!!
I believe it is your theremostat, maybe the heating element,
I would use a multimeter if you have one and set it on ohms touch it to the terminals of the thermostat, and the heating element (if you don't have a multimeter walmart sells a cheap one that will work fine for what you are doing) if you do not get a reading replace, http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=493992
Here is the list for all your parts
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=392096&ST=PBM
Sep 14, 2009 | Dryers
Whirlpool electric dryer, Model LEC6646ANO. On
Make sure the internal and external exhaust vents are not blocked with lint.
Will it complete a 45 minute time dry and dry the laundry?
Mar 09, 2009 | Whirlpool Dryers
Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
Dryer Heats on High all the time
I don't think it is the heating elements. You have checked out all the important stuff. Is there power coming from the controls on medium and low. It sounds like this is the problem.
Jan 23, 2009 | Frigidaire FEQ332E Electric Dryer
Consequences of using high heat in dryer
the vavle in using high heat only comes in to play when you have a load of towels or some other heavy cotton,,thats what high heat is mainly for,,more moisture,,,on the norm medium with a regular load is the way ..now go to the dryer and look at the back vent where the heat comes out does it look like burnt and dark as if you burnt shirt and it stuck to the iron,,that comes from high heat scortching,,rubber in elastic in your sock and other clothing...onthejob slow low and steady
Dec 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
158 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
