Question about Cisco (1841) Router (cisco1841)
Cisco 7206 allows telnet but no traffic or ping
As many others here.... I am new to Cisco: so here it goes.
Hardware:
- Cisco 7206 - 4 (8port) cards installed
Layout:
--DeviceC1 --- DevD1....etc
--DeviceC2 --- DevD2....etc
DeviceA --- DeviceB ---<---DeviceC3 --- DevD3....etc
--DeviceC4 --- DevD4....etc
--DeviceC5 --- DevD5....etc
--DeviceC6
DeviceA - my laptop or any other device this side of 7206
DeviceB - Cisco 7206
DeviceC1-6 - Cisco 3745/3725 Routers configured as Multilinks
Basic Config points:
- 6 multilinks defined, 5 are working (all are 3745/3725)
- 1 of the 6 will not allow traffic (DevC5)
- 1 direct serial, also working
Symptom:
- Able to telnet to remote router 3745 (DevC5) only from 7206 (DevB)
- Able to ping to 3745 (DevC5) only if telnet into 7206 (DevB) first
- If 2 hops away at DevA, then DevC5 (3745) then it is not accessable.
- From DevB I can telnet into DevC5 or anyothers downstream (DevD5..etc)
- Cannot telnet into DevC5 except from DevB
- But all these things work fine with DevC1,DevC2,DevC3... etc...
- Only DevC5 is acting funny
- You can also ping back from DevC5 to DevB, but not to DevA
Question/Problem:
- Why is Multilink5 to (DevC5) not allowing traffic, but you can see it?
    Scholar:
  • 108 Answers
Http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/UC5.0.1/ipt_system_arch/COL_QOS.html
Sounds like maybe a QOS issue. Click the link above to see if this helps.
Also, could be a load balancing issue. Let me know if this helped.
Posted on Jan 17, 2009
My dell 8300 keeps losing connection with the internet, the connection is good the ethernet light is red
1. Disable your windows firewall immediately or allow the firewall to permit the ping.
2. 127.0.0.1 is loopback address to ensure your network card is working fine.
3. Change the network cable with serviceable one.
4. Un-install the driver and reinstall with new one from OEM site
Jan 05, 2012 | Dell Ethernet Card Network Adapter
While i am receiving or dial a call from my 7936 Cisco ip phone other party and even i can not get any voice from both side. Only the dial ring is working. please dissolve this problem
Sounds like a classic "IP" routing problem. Make sure both end points can ping each other. The other possibility is a firewall issue where the firewall is blocking the RTP (voice) traffic.
May 21, 2010 | Cisco 7936 (cp7936ch1) Audio Conference
Connecting a 3Com 2952 Plus switch to a Cisco 3750 switch
If you also have a standard copper cable (or a second fibre cable) connecting the two switches (for resilience perhaps?), this issue is probably being caused by something called Spanning Tree. This is implemented on switches as a 'loop avoidance' system, and can look like you have described with one end 'ip' and the other end no lights.
On the Cisco switch, get to a telnet/ssh/console session, log in and enter show spanning-tree and press enter.
have a look to see if the fibre interface has a status (sts column) of BLK. If it has, then this is called 'blocking' and will remain like that until you remove the second link to the other switch.
Hope that this has helped!
Mar 03, 2010 | 3Com 3CSFP91 Transceiver
Cannot Ping using NetXtreme 1000SX on IBM x3400 w/Linux SUSE 10.1
Are you pinging from the same subnet? If not, you will need to have a default gateway. Type "ifconfig -a" to verify you configuration. Type "netstat -r" to see check the routing. And type "netstat -i" to see if there is any traffic on the interface.
Jun 12, 2009 | IBM NetXtreme 1000SX (22P7809) Network...
I am trying to telnet through a Linksys RVS4000 from the wan side of the router to a fixed device on the lan side of the router. Both networks wan & lan are operational and I can ping the Wan side...
run netstat on the lan pc to see if telnet server is listening on port 23. look at logs on the router and pc to see if it is blocking any traffic. make sure lan pc has route back to wan
May 14, 2009 | Computers & Internet
Cannot able to Ping or Telent Managemnet IP address
Did you setup telnet login and password? Are plugged into a port that is disabled or not programmed right.
Mar 29, 2009 | HP Blc Cisco 1GBE 3020 Switch Kit...
Cannot telnet to SN0108 altusen serial over net
Please change the ip address to 192.168.1.32 or something and try telnet.  Thanks ,
Vipin
Mar 16, 2009 | Altusen 8PORT POWER ON THE NET W/ (PN0108)
Cisoc 2950 with odd Problem
I recently had a client switch do this to me. The only way to get it working was to manually put the NIC on my laptop to 10 Mb and Half duplex. After calling Cisco and opening a TAC case, it was deemed faulty hardware.
If you have SmartNet (anyone buying Cisco should always buy SmartNet) on the switch, call TAC and open a case. It's probably faulty hardware.
Good Luck!
Feb 02, 2009 | Cisco Catalyst 2950 24x10/100 Mbps...
I have a Cisco 7206 and it does not recognize a pa-8e port adapter
Hi Ckrebs,
Can you check what is the ios version of the 7206 (the one not able to recognize the PA-8E)?
Minimum versions of IOS required for pa-8e are the following:
Cisco IOS Release 12.2(4)B or a later release of Cisco IOS Release 12.2B
http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/ethernet/pa-8e_10baset_install_config/3494prep.html#wp1024649
Check the ios of the router if it supports the PA since you were able to isolate that it's not a faulty PA-8E (by testing it to another 7206 chassis).
Once checked, can you provide the show version and show diag output?
Regards,
ex_ocsic_cat
Oct 20, 2008 | Cisco (PA-8E=) Expansion Module
Siements 5890 router
When you say HQ is that outside on the wan port trying to ping the Lan port?
Sometimes the router itself will respond to a ping but will not pass ping requests thru as the internal firewall can never be fully shutoff unless you are running your cisco switch as a DMZ
also are you connecting your other pc's to the cisco or to the 5890.
Instead of shutting off the firewall completely try enabling bridge mode and give your cisco the outside IP addy.
Apr 30, 2008 | Computers & Internet
Cisco (1841) Router (cisco1841) Logo
294 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
