Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Canon PIXMA MP140 error code E
The problem is the following ink cartridge can not be recognize.-colour
  • 2 more comments
  • mhamedfree Nov 09, 2008
    I ve just bought a new canon mp140
    i ve inserted new cartriges one black the other in color but the code error
    appeared E that i really do not know what is it even if i restarted the printer  the computer but invain
  • sortedagain Feb 12, 2009
    i have an error code of E16 since i fitted a refilled cartridge on a mp140 do refills work?
  • Feynman Feb 28, 2009
    I have the same problem with my MP140 after changing the original black Canon cartridge for another non Canon but compatible black cartridge. After printing some documents, the printer suddenly stopped, and returned the flashing error code E and 4.
    Is there some trick to fool the Canon software.
    I have had a similar problem with my former HP printer.
    Thanks in advance for any help
  • Anonymous Mar 30, 2009
    WHEN printing some documents, the printer suddenly stopped, and returned the flashing error code E and 2.
    Sergeant:
  • 284 Answers
Replace with genuine cartridges is the best policy.
Posted on May 31, 2010
  • ayabowman Mar 14, 2011
    Of course Canon are going to say replace only with Canon cartridges - they want to make money. I use GOOD compatibles with two or three times the ink quantity and they work fine in my machine and save me a lot of money.
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
E5 flashing - do not want to use colour ink
use any color cartridge that is no sort & see canon error e5 solution
Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Service error 5100 canon MP140 series
Try cleaning the contacts on the printer and the cartridge with rubbing alcohol. Then unplug the printer for 10 mins. If that does not work contact the cartridge manufacturer and they should send a replacment.
Feb 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Coloured ink not registering
You can only refill those cartridges if you do it before the ink is empty. After that you need a new cartridge or a chip resetter to reset the chip on the cartridge so it will work again.
Oct 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
I have a pixma mp10 scaner and printer it will not scan the light flashes E and 6. What can I do to fix this? Barbara Nash
Halo Barbara,
Did you mean Pixma MP140/160/150/170/180?. I never hear Canon pixma MP10. Well,it doesn't matter. Did you refill your cartridge?. Error code E6 indicates that ink level is not detected properly by the printer. It usually occurs in refilled cartridge. To fix this problem you need to deactivate ink level detection function by performing following procedure:
For MP150/160/170/180: Press START button (Black or Colour)
For MP140: Hold down STOP/RESET button for about 9 seconds
Please rate me as Fixya if this solution useful for you. Thanks
Source:
Canon Inkjet Printer Forum
Nov 27, 2008 | Canon Office Equipment & Supplies
MP140 do not recognize cartrige
Ensure that you are using original cartridges.
Clean the cartridge sensor inside the printer ink carriage with isopropyl alcohol and cotton. From description it looks like a faulty cartridge contact.
The cartridge sensor is the metal plaque that connects to the cartridge chip, is located inside the printer carriage.
Nov 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
2,049 people viewed this question
old marine
old marine
