Question about Garden
Toro line trimmer model TB90BC
Ok now when I first start the trimmer cold I put it on full choke of course then when I hear it pop or act like it wants to start then I put it on half choke and so on. It will start sometimes but when it does start it will run only for like maybe 5 seconds then cuts right off everytime it starts. I just got finished taking the carburetor apart then soaking it the carburetor cleaner yea know the little paint looking can with the basket in it by gunk. And it still is doing the same thing. I am thinking vapor lock but I tried to start it with the cap of o yea and I tried starting it with the muffler off also and still the same symptoms please help thank you.
  • 1 more comment
  • Missourian May 08, 2009
    This is sthe third line trimmer from toro that I have had this problem with. I only get one season out of the trimmer. Where I purchased the trimmer from has replaced it twice. There was no old gas in the tank, I used new gas. The trimmer would start, but when I tried to accellerate the throtle, it would die.
  • Anonymous May 20, 2009
    I have a Troy BC90BC and it has the same problem. Its about three years old and I have done everything under the sun to solve this problem of not want to run at full speed. It will only run with the choke handle in the middle and stalls if you give it any gas. Does anyone know of a brand of string trimmers that doesn't preform like this.
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    does it only start with the choke on? does it only start if you primer it first?
    Scholar:
  • 76 Answers
First you may want to check your fuel that is in the tank, how old is the fuel and was there any old fuel in the tank before you put fresh fuel in? Todays gas isn't as good as it used to be the ethonol in fuel is eating pretty much anything that is made of rubber in our 2 & 4 cycle engines cleaning doesn't always help. You may want to try a rebuild kit for it. And re-adjust the high and low idle needles (jets).
Posted on Jan 08, 2009
Weed wackier gas trimmer
didnt specify the make and model so generic answer ---check fuel mixture is correct --check the filter in tank is not plugging up--look for damaged / crack in fuel feed lines-look at spark plug --carb may need cleaning --exhaust port may need cleaning
Jul 04, 2016 | Garden
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
Trouble shooting New Toro Power Clear 418 zr - slight misses and pops while running
when you start it do u use the choke right , when starting close choke when it starts open choke you prob fouled the plug clean it put back it walah
Nov 22, 2013 | Toro Power Clear 418 ZR - Single Stage...
TB90BC WON'T START
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ``
Feb 06, 2012 | Troy Garden
Hard start tb475ss troy built weed wacker when i close the cold start lever it starts but its 75 degrees out its like the primer ball is inop but i see fuel moving through the lines when priming did not...
These 4 cycle trimmers need to be primed 10x before a cold start. The bulb will feel *firmer* on the last two or three depressions and you'll know that the carb is primed.
Full choke and and full throttle on first tug should see it hit once with a puff of smoke. Second start attempt should be in choke position two (half choke) and with full pressure on the throttle. Should rev to life on start attempt. Let the engine IDLE for 30 seconds, moving the choke to off at the end of the waiting period. Let engine idle to warm another full minute with no choke, then set to work!
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Craftsman weedwacker keeps dying
If the weedwacker runs OK on 1/2 choke or even better on full choke then most likely the cause is the carb gaskets are stiff and can no longer pump the fuel. Of course make sure the fuel lines are are the right ports (return and supply). While you have the carb apart clean all of the passages with carb cleaner.
Apr 16, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
657 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
