Question about Honeywell ER150B Air Conditioner
Honewell air conditioner wont turn on
The air conditioner does not come on when i turn it on at all. It just stopped out of nowhere. I tried changing the filter and checked the setting on it to make sure it wasnt on hold still nothing. Please help me
thank you
  • 306 Answers
Sounds like with the limited infomation that you lost a capacitor inside the condenser. need more info. Does the fan inside the furnace come on?
Posted on Nov 23, 2008
My unit does not go on. I press the on button and hear it then 10 sec pass hear it but it doesn't light and red light doesn't go on and then it shuts off
tep 1: Check the thermostat
  • Make sure that your thermostat is set to "cool" and not "heat" (if it's set to heat, your AC won't turn on no matter what).
  • urn the temperature setting 5 degrees below the current temperature to see if your AC will turn on.
  • No good? Then you need to...
tep 2: Check the air filter
  1. Find your return vent's filter (the return vent is where air gets sucked into the air conditioner).
  2. Check to see if the filter is dirty (if you can barely see light coming through it, it's too dirty).
  3. Change the filter if it's dirty.
    "Wait, why am I doing this?"
    A dirty air filter blocks air from returning to the AC, reducing airflow over the evaporator coil, causing it to ice up.
    This causes a low-pressure switch to trip and shut down your AC's compressor (the heart of your air conditioner) to prevent it from being damaged.
    So you need to change the air filter to prevent all that.
Sep 28, 2016 | Heating & Cooling
Tip
How to Reset Your Air Conditioner Filter Light
<span style="font-weight: bold;">Cabin Air Conditioner:</span><br /> <ol> <li>Press and hold down the Off button for 4 seconds.</li></ol><span style="font-weight: bold;">Carrier Air Conditioner:</span><br /> <ol> <li>Press the Reset Filter button to reset the timer that calculates the next air filter change after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Daikan Air Conditioner:</span><br /> <ol> <li>Press the Filter Clean Reset button to reset the CLEAN FILTER INDICATOR after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Frigidaire Air Conditioner:</span><br /> <ol> <li>To reset after cleaning the filter, press the "Filter Reset" button and the light will go off.</li></ol><span style="font-weight: bold;">GE Air Conditioner:</span><br /> <ol> <li>Turn the air conditioner OFF and unplug it.</li> <li>The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter.</li> <li>After cleaning, replace the filter and plug the air conditioner back in.</li></ol><span style="font-weight: bold;">Honeywell Air Conditioner:</span> <ol> <li>Press and hold the i button until the timer is displayed, followed by pressing the Up Arrow button (next to the Wake button)</li> <li>Press the Run Program button.</li></ol><span style="font-weight: bold;">Kenmore Air Conditioner:</span><br /> <ol> <li>To reset the filter indicator, press and hold the filter reset button for 3 seconds.</li></ol><span style="font-weight: bold;">Lexus Air Conditioner:</span><br /> <ol> <li>Without having foot on the brake, press the Start button twice to get to the IG-ON position.</li> <li>Then press and hold the "hard" OFF button next to the "hard" Auto button. Hold the OFF button for approx 5 seconds and you hear several beeps.</li></ol>or<br /> <ol> <li>Turn the engine switch to IG-ON mode.</li> <li>Push and hold the A/C OFF button for more than 4 seconds.</li></ol><span style="font-weight: bold;">Lexus 2008 Air Conditioner:</span> <ol> <li>Push the "INFO" button & touch "Maintenance".</li> <li>Touch the desired button Delete All: To cancel all conditions which have been input or Reset All: To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.</li> <li>Input the Notice of Date: The next maintenance date must be input.</li> <li>Now input the Notice of Distance: The driving distance until the next maintenance check.</li> <li>Delete: To cancel the date and distance conditions.</li> <li>Reset: To reset the date and distance conditions.</li> <li>Touch "OK" The screen returns to the "Maintenance screen.</li></ol><span style="font-weight: bold;">Lincoln LS 2001 Air Conditioner:</span><br /> <ol> <li>Press and hold the setup button above the radio until it says system check. NOTE: All the doors must be closed.</li> <li>Watch the system check when it goes to A/C filter hit the reset button.</li> <li>Hold down the reset button to confirm.</li></ol><span style="font-weight: bold;">Lincoln LS 2003 Air Conditioner:</span><br /> <ol> <li>Press the STATUS control to access the System Check function, the message center will display A/C FILTER XX% RESET FOR NEW.</li> <li>Press and hold the RESET control to set to 100%.</li></ol><span style="font-weight: bold;">Lincoln LS 2005 Air Conditioner:</span><br /> <ol> <li>Insert the key and turn the ignition to "Run" or "On." It is not necessary to start the engine.</li> <li>Press the "Status" button above the radio until the system display changes to "AC Filter."</li> <li>Press and hold "Reset" above the radio. The system will beep and the "AC Filter" display resets to "100%."</li></ol><span style="font-weight: bold;">Maytag Air Conditioner:</span><br /> <ol> <li>Press the "Fan" button 2 times, then press the "Mode" button 1 time and it will reset.</li></ol><span style="font-weight: bold;">Whirlpool Air Conditioner:</span><br /> <ol> <li>Push in the filter reset on the remote using a straightened out paper clip or similar.</li></ol>or<br /> <ol> <li>On the control panel, press and hold the Mode and the Up Temp Arrow buttons for 6 seconds.</li></ol>or<br /> <ol> <li>After having cleaned the filter just press the reset button located on the indoor unit behind the front panel to interrupt the flashing of the filter monitor indicator.</li></ol>
on Jun 17, 2011 | Heating & Cooling
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
My 12000btu spliter air condition start and stop in 5 seconds
24
EN
TROUBLESHOOTING
CAUTION
If any of the following conditions occur, stop the air conditioner immediately, turn off the main power switch and contact the
dealer.
• The indicators flash at short intervals (5 Hz). Reset the circuit breaker 2 to 3 minutes after the power main switch is turned
off.
Despite the resetting operation, the indicators still continue turning on and off.
• The main power fuse often blows, or the circuit breaker is often activated.
• Foreign matter or water has fallen inside the air conditioner.
• Any other unusual conditions are observed.
Before asking for servicing or repairs, check the following points.
Recheck
Inoperative
• The power main switch is turned off.
• The circuit breaker is activated to cut off the power supply.
• The main power fuse has blown.
• The electric current has stopped.
• The batteries in the remote controller used up.
• The ON timer is set.
• As a protective mechanism for the air conditioner, it does not operate for 3 minutes
immediately after restarting operation or turning on the main power.
Poor cooling or heating performance
• The air inlet or outlet of the outdoor unit is blocked.
• Doors or windows are opened.
• The air filter is clogged with dust.
• The louver is not at the correct position.
• The fan speed is set to low.
• The air conditioner is set
to the DRY or SLEEP MODE.
• The temperature setting is too high (during cooling operation).
• The temperature setting is too low (during heating operation). (heat pump models)
Feb 01, 2015 | Samsung AS18A6RB Air Conditioner
Why is Unit not cooling?
Good Morning Friend,
I understand your Frigidaire air conditioner, model# FAS296R2A, is not cooling. I also see that, both the filter and condenser are clean. First, try setting the temperature lower. Secondly, the compressor could have shut off by changing modes. Set to the "COOL" setting and wait about 3 minutes for the compressor to restart. Lastly, check the temperature sensing element, located behind the air filter, to make sure it is not touching a cold coil. If it is, straighten the sensor away from the coil. I hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FAS296R2A Air Conditioner
I have ice shooting from my air conditioner, How can I solve this problem?
I understand you have ice shooting from your Frigidaire air conditioner, model# FAK104R1V, and want to know how to stop this from happening. First, check the air filter to make sure it is clean and there is no frost build-up on the cooling coil. If the coil is frozen, set your air conditioner to "Fan Only" mode, to defrost. Then set the temperature to a higher setting. Secondly, I suggest slightly tilting your air conditioner to the outside, to allow water drainage. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Frigidaire FAK104R1V 10000 BTU Portable...
Air conditioner blower stopped blowing
It could be a fuse, or the blower motor resistor.
Jun 27, 2009 | 1995 Pontiac Grand Am
Heat doesn't work on ac unit
u have to be more specific. is it gas or electric. If electric check breaker first. Gas check thermocouple
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
Honeywell ER150B Air Conditioner Logo
556 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
