Hi i am tryning to load an operating system onto my brand new hard drive. It keeps coming up with disk boot failure, insert system disk and press enter.. what do ido
    Sergeant:
    Champion:
  • 435 Answers
Hi, By brand new harddrive, I assume that its fresh and empty.
You need to install the Operating System (OS) in that harddrive.
You can do that my inserting the OS installation CD/ DVD into the drive before you bootup.
If you still get the error, get into the setup mode and change the boot sequence to boot from CD-ROM first.
Hope it helps :)
Posted on Sep 21, 2008
I am unable to format my 40 GB Hard Disk (samsung) with WinXP Installation CD. After Doing Patition and format it comes unable to format
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
hope this helps
Aug 06, 2011 | Samsung (SP0411N) 40 GB Hard Drive
How to format N 2600c 2 and what is its code
cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
or if you are trying to format a usb drive
insert your pen drive
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jun 16, 2011 | Computers & Internet
Windows was unable to complete formatt
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive) or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
another way is to control panel administrive tools,computer management disk management right click on your drive select format hope this helps
Feb 28, 2011 | Computers & Internet
HOW CAN I FORMAT A 250 HITACHI HARD DRIVE WHEN IT WOULDN'T LET ME
cmos to restart
Feb 17, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
Hard disk not aacept formet
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
this will erase you operating system you have to have a operating system disk to load it onto you hard drive or create a partition to load another operating system
hope this helps
Dec 03, 2010 | Samsung SpinPoint V80 SV0802N 80 GB...
HI THERE, I AM TRYING TO INSTALL A FRESH COPY OF WINDOWS ONTO A ANOTHER COMPUTER, I AM USING THE CD'S I ALWAYS USE SO THEY ARE BOOTABLE DISKS, I KEEP GETTING MESSAGE BACK "DISK BOOT FAILURE, INSERT SYSTEM...
First you need to make sure that the CD drive is selected as the first boot device.
You can set that by going into BIOS setup by pressing Del/F2 during system startup OR during startup press F12 and select CD drive from the boot device selection menu.
Press Enter.
See if the system is able to start from the disc.
Thanks
Feb 20, 2010 | Computers & Internet
2 hard disks
Because you have a dual boot system, you have two 'C' drives, which in fact is a good idea if you get a system failure on the drive you are using, you can select the other and still view any files on the other drive through my computer.
f using XP, right click my computer, then properties, then click advanced tab, then startup and recovery listing click settings, at the top system startup, select the default operating system, then click EDIT button, then delete the value that points to the other hard drive more than likely listed as disc1, disk 0 will be the one you have connected as master boot hard drive
Aug 29, 2008 | Microsoft Windows XP Professional With...
Istalling windows
Consustently get "DISK BOOT FAILURE _ INSERT SYSTEM DISK AND PRESS ENTER" message
use xp sp2 bbootable disk and simply run a repair installation it should heal your system
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
