I have a Maxtor MaXLine PlusII 250GB External Hard Drive 7Y250P0 that I purchased in May 2004.I have never used it since purchase, but have finally decided to do so. I have lost the Installation CD that came with the the product, so can't install to my PC. Where can I beg, borrow, or get a copy of the Install CD?
  • 781 Answers
You may not need one.. onless your os is 98... do you get an error when you try to connect it?. is it asking you for a device driver??.. if you're using win xp or vista.. connecting an externa hard drive is pretty much the same as connecting a flash/thumb drive.. you just plug it in to an unused usb port and off you go.
Posted on Sep 21, 2008
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
External hard drive stopped working
Hmm any sort of nise from the disk is not a good sign. try using the unit on another Pc. if you have the same issue you might have to take it for warranty.(if you have warranty)
May 22, 2009 | Maxtor OneTouch II external hard drive...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Hard drive wont show up
change the jumpers to slave if it is on the same cable as the master should show up
if it is set now on master it wont show up
Feb 23, 2009 | Maxtor MaXLine Plus II 250GB 7200 RPM...
Reformatting external Hard Drive
click on the hard drive and use the disc manager to format
or right click on the hard drive properties and use the format tab
May 11, 2017 | Maxtor BASICS Personal Storage 3200...
Unable to see the 250Gb external drive shown on 'my computer' when plugged in
Hi - thanks for your quick response, much appreciated .........I will try again to explain!!
We have purchased a 250Gb Maxtor portable hard drive which I was told was plug and play. We have followed the instructions for connection but no drive letter is showing up and the external drive is lit up and making a constant beeping noise. The computer doesn't seem to be recognising that an external drive has been connected.
To test our computer out I have connected an 8Gb memory stick to the processor and it shows up as drive H immediately.
FYI - we have XP running on our machine.
Hope you can help!! Thanks
Oct 25, 2008 | Maxtor MaXLine Plus II 250GB 7200 RPM...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Can't format or create partition......
It maybe that your motherboard bios cannot support 250GB and needs an update, but caution applies here. The other problem maybe that you need to use the hardrive on the 'CS' (Cable select setting). Lastly if you already have a pc running, use this drive as the slave the go to the Maxtor website to make use of the diagnostic/formatting and partition tools.
Feb 27, 2007 | Maxtor MaXLine Plus II 250 GB Hard Drive
you can try an FDISK form a windows boot disk, but you may need to read up a little on how to use it. or maxtor has a program available on their web sit called powermax that can try to find & repair possible problems. powermax may be the best & easiest way to go. good luck.
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
