Question about Toshiba A75-S125 Satellite Notebook
Toshiba a75-s231 Hi, A75-S231 will not boot up. When I turn the CPU on the scree that that says startuu in safe mode start up if the last configured setting start up normal ETC Wheever I press any of these option my CPU simply reboots onto the same screen??????????????????? Any help would be appreciated :) Mike
  • 3 Answers
Your laptop's hard drive must be corrupted. Try a clean install of your operating system or try using the recovery cds included with your laptop.
Posted on Sep 21, 2008
Toshiba Satellite A75-S231 overheating pls advise me
You need to open the Notebook and clean it with an Air-blower mainly near the CPU (Processor) area.
You need to check whether the CPU cooling fan is working properly or not, try cleaning it too, If the problem still persists replace the CPU cooling fan.
That's it.
Feb 03, 2010 | Toshiba Satellite A75-S231 Notebook
Toshiba Satellite A75-S231 overheating and unexpected shutdown. I tried dismantling the laptop to clean the fan and heatsink, but I was not able to open it completely. Pls could you guide me and assist me...
I have a Satellite A75-S2292. It did the same thing to me. I just blow the vents & fans out weekly with canned air. I also have an under the laptop cooling fan, to increase the air flow. I haven't had it shut done for months, since I started doing some preventive maintenance.
The changing the thermal paste is not a good repair. Thermal paste will last for at least 20 years, under worse conditions than most computers will ever experience. Removing the processor chip, wiping everything clean & replacing the paste & chip just make more chances for damage.
Oct 29, 2009 | Toshiba Satellite A75-S231 Notebook
When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    I need to reinstall Windows on my Toshiba A75-S231
    You can usally find this in your D: Drive. It should already be pre-loaded. Make sure you have made a back up disk as this procedure can wipe out all your programmes that did,nt come with the comp
    Feb 12, 2009 | Toshiba Satellite A75-S231 Notebook
    Start menu toolbar does not appear on desktop
    check this out maybe it can help..
    in the desktop..put the cursor and right click-properties-select desktop-customize desktop-check the desktop icons you want..and click ok...just try maybe this is only you want..
    Jan 04, 2009 | Toshiba Satellite A75-S213 Notebook
    Remote Procedure Call (RPC) service terminated
    do one thing ...
    start the system and make sure you are fast
    when the system starts up click on the start > run > type > services.msc
    in the list find the remote procedure call ( RPC ) and double click on it > click on the tab that says recovery > and than make sure the failures say take no action and than apply and click ok
    Dec 23, 2008 | Toshiba Satellite A75-S231 Notebook
    LCD lost the red color
    First, plug a external monitor and toggle the screen with ALT+F4 to see if the image is correct there. This will discard software or configuration problems.
    If the image in the external monitor is OK you problably have a hardware problem in the LCD panel or its cabling.
    You can get the replacement parts here:
    http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
    May 13, 2008 | Toshiba Satellite A75-S231 Notebook
    Unexpected shut down
    First, you need to find out what is causing the shutdown problem.
    Most likely since you have this laptop for 3years now and (i am assuming you havent had this serviced). You might be suffering from overheat problems since you are using a DESKTOP P4 cpu.
    Try to dismantle your laptop and remove the Fan and Heat sink. CLEAN them and put new thermal paste to the cpu.
    Do that and see if this fixes the problem. If not, let me know again
    If i was able to help please rate this solution as a fixya!
    thanks
    Apr 11, 2008 | Toshiba Satellite A75-S231 Notebook
    Toshiba A75-S125 Satellite Notebook Logo
    108 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
