Question about SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD error message - Disc is Write-Protected
I just bought a SanDisk 2GB microSD memory card for my phone, an LG enV2, in order to save music to it. When I tried to save music to it from my laptop it gave me this message: Disc is Write-Protected. The same message displays when I tried to rename the disc and when I tried to reformat it using the laptop. I tried switching the tab on the side of the adaptor down to "lock" and up, presumably to unlock. I tried right-clicking on all the folders on the disc in order to undo the "read-only" attributes. When I re-checked the attributes, the change had not been kept, although I tried clicking "Apply" before clicking "OK". Simply put, how can I un-Write Protect my SanDisk?
  • 1 more comment
  • Enrique Ortiz Sep 21, 2008
    Aminic,
    Thanks for the quick response. I reformatted the disk in my phone and had the same results. I attempted to format it from the computer. Again, it read the disk as write-protected. The phone salesperson invited me to come by to have a look. I shall post the solution when I find it since others are probably having the same problem.
    Gratefully,
    RicoRico
  • Enrique Ortiz Sep 25, 2008
    For all others with the same problem:
    I bought a microSD card reader and I can now use my microSD card without any problems. Apparently my old reader does not do well with the card.
    Readers are available in many places. Prices range from as little as $10 to as much as $80. My friendly neighborhood Verizon store carries them for about $24.
    RicoRico
  • Anonymous Nov 28, 2008
    hupnjuhpiiiiiiiiiipnmjuikiujnk
  • 61 Answers
Re-format it. Put the SanDisk 2GB microSD memory card into your LG enV2 and format it from there. If that does not work plug it into your laptop then right click the icon and format it to FAT and click on default settings.
Posted on Sep 21, 2008
  • Aladdin Minic
    Aladdin Minic Sep 22, 2008
    Just buy a new one since it is a failing.
My SanDisk 2GB microSD Memory Card is not being detected in any device.
the connect tabs on the sd card might need to be cleaned if they are discoloured brown or black it might be the problem you could use alcohol or just a gentle scrape on the tabs to clean them
hope it helps
Dec 30, 2011 | SanDisk 2GB microSD Memory Card
I cannot reformat my 2gb Sandisk thru my laptop and thru my LG KS360 phone because it is right protected and i forgot my password. Thanks
your adaptor lock button slide is slipping to locked appy small peice of tape and should be good
if it helps please thumbs up
May 08, 2011 | SanDisk 2GB microSD Memory Card
I Place My Memory Card ( SanDisk 2GB ) Into Phone - Not Working
Not all phone support high capacity microSD, check your phone spec and capability of handling microSD
Apr 30, 2010 | SanDisk 2GB microSD Memory Card
Memory card write protect?
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!...just make sure the lock is off!
Jun 02, 2009 | SanDisk 1GB microSD Memory Card
LG env2 will not save text messages
This happened to me. My problem was that i had a memory card, and i accidently put the save options for my pictures to my phone memory instead of to card memory. So it messed up my phone.
May 30, 2009 | Verizon Communications enV2 Cellular Phone
Formatting
Hello Laurakeeney1
I would check to make sure your SD card in not Set to Write Protected, if it is not follow this link for a Flash Memory format utility that I use to fix any problems i have with Flash memory
HP USB Disk Storage Format Tool - v2.1.8
http://files.extremeoverclocking.com/file.php?f=197
Hope this Helps
May 05, 2009 | SanDisk 2GB microSD Memory Card
Sandisk microSD 2GB : well formatted on cellphone but...
its not the adaptor its the card hence it gives you the error means it can access it. is the card working 100% when you plug it back to the phone?
Mar 09, 2009 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
1,125 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
