Question about Milwaukee 5321-21 Rotary Hammer
Wont run continuously
When i press trigger it runs for about ten seconds and then stops. you repress the trigger again and it runs for ten seconds again. it just will not stay on until i say when. whats up with this thing
  • cynjun Sep 26, 2008
    no this is not the fix. it did not work.
  • David Ford
    David Ford May 11, 2010
    I would look at the brushes and clean area with compressed air. Sometimes the brushes get hung up in the holder and make intermittent contact. Second if this tool is not that old it might still be covered under warranty. Good luck
    Problem Solver:
  • 17 Answers
Hold the button in all the way
Posted on Sep 26, 2008
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
Washer repeats entire cycle - does not stop at end of spin cycle.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel.
I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Jan 23, 2013 | Kenmore 2.1 cu. ft. Compact Portable...
Fisher & Paykel Frigidaire Excellence 7.5 clothes washer Model: GW709NZ Ser:NPL579002 the clothes washer starts as normal, water runs for approximately ten seconds and then stops, runs for two to...
May be one of the fill valves are not opening when it is calling for either cold or hot water. Have the solenoids checked with an ohm meter
Feb 26, 2011 | Washing Machines
I have a 2007 chevy tahoe with factory installed auto start. what buttons on remote or what sequence do i push to get truck running?There is a lock button an unlock button a rear glass open button and a...
To get your truck running with auto start first press the lock button and then hold down the semi cicle button for about 3-5 seconds this will start your truck
Jan 28, 2011 | 2007 Chevrolet Tahoe
Miller plasma cutter stops cuttingafter a few seconds
the cutter probably has a built in current monitor. that trips out then resets itself. try a lower current.
Mar 24, 2009 | Welding Tools
Drill keeps on stopping and won't restart
Check the cord...sometimes if the brushes are not seated well or if there is a cut in the cord you will run into that problem....If it is not that then possibly you just have a faulty drill
Jan 04, 2009 | Drills
Powermate pressure washer Model PW0872400
pressure washers has this pressure switches where in as you press on the trigger, the washer works and if you release it, the pressure would build up high and it would trip this switch to turn off the motor or deflect the water to the by pass hose ( if the motor is not stopping) then as you press again the trigger, water should come out of the gun again but would not,
i have encountered the problem is in the pressure switch, even the pressure went down, sometimes it wont close the contact then the motor wont run ,
if the motor is continously running, then the trigger switch is the problem, the pressure excerted on the switch is so high that even if you press it , it won't open up to release the water.
what i can suggest is to tie the trigger in the gun so that it is always pressed and then just unplug the unit if you want to stop using it. it is an inconvenience but it will work.
or, open the gun and see if you can figure out why pressing the trigger would not open the switch.
another option is you can lower the pressure of the washer if it has an adjustable pessure controller. by lowering the pressure might open the switch when ever you press the trigger.
i hopw i was able to fix...
good luck,
drcool
Aug 21, 2008 | Coleman (100076) Compact Refrigerator
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Milwaukee 5321-21 Rotary Hammer Logo
221 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
