Hitachi SF-H800PX my machine is half way through a cycle and it has come up with a E1 error and is still full of water regards Dianna
  • Anonymous Mar 29, 2014
    I have Hitachi Cloath washing machine type: SF-P110CJ "Fuzzy Control" . I am having problem with my Hitachi washing machine it shows E1 error, what shall I do to correct it
    I have Hitachi washing machine type : SF-P110 CJ "Fuzzy Control" I am having problem with my hitachi washing machine it shows E1 error, what shall I do to correct it
Water supply malfunction.....maybe the inlet valves???????
Posted on Apr 10, 2009
SF-P95JJ GIVE ERROR C9
Not "hitachi washing machine error code c9 what to do"
electronicsfurnitureinfo.com/.../hitachi-washing-machine-error-code-c9-...
Info about hitachi washing machine error code c9 what to do in Electronics ... What do you think about this washer Electrolux ZWT-61M, do you like the design?
Jul 28, 2015 | Washing Machines
Hitachi sf-6500px error
Possible error on the program due to a memory issue. After resetting, if the machine has the same fault with all the selected programs, then it is possible that the motherboard is faulty. Please check the INLET flow to be good and the drain pump to be clear.
Jun 25, 2013 | Washing Machines
Model:SF-95CJ F9 FAULT CODE
my hitachi model SF-95 CJ is washing machine show F6 ,C4, F4 FAULT CODEcleck
Feb 11, 2012 | Washing Machines
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
Jun 23, 2011 | Washing Machines
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
"E 1 code error
E1 is a drain error. On the unit prior to mar 07 LG had a problem with wires breaking in the door. Turn off power supply, remove door panel and look for wires stuck in the insulation. Check continuity of the wires, if broken, splice and tape. Place insulation between black insulation and wires to prevent reoccurence.
Sgt 48
May 24, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
