Question about Sanyo Televison & Video
Automatic on when plun in, did not function with remote
    Champion:
  • 317 Answers
Has a bad relay.
Posted on Sep 21, 2008
What is an ICP - RCC - Speedometer fuse for on a 1997 ford taurus dohc ICP - RCC?
Hey Brian ,
ICP - Integrated control panel
RCC - Remote Climate Control Module
Integrated Control Panel-Electronic Automatic Temperature Control
Control Assembly The Taurus, Sable vehicles group together the following systems into a single integrated control panel:
  • AM/FM stereo radio
  • clock
  • rear window defroster switch
  • electronic automatic temperature control (EATC)
  • full-logic cassette tape player
  • compact disc player control (optional)
The remote climate control module is mounted to the A/C evaporator housing behind the integrated control panel. The integrated control panel is connected to the remote climate control module with a dedicated two-wire communication link. The integrated control panel EATC features:
  • a vacuum fluorescent display (VFD) for displaying set temperature, ambient temperature, function and diagnostic trouble codes (DTCs).
  • electro-luminescent backlighting for all buttons and graphics.
  • function override buttons.
  • temperature control and blower speed rocker switches.
Jun 08, 2015 | 1997 Ford Taurus
Cobolt 3 in 1 jumbo remote control
have u checked wether is is supported or not????
it may not be supported.............
Sep 18, 2008 | Televison & Video
Why is the oven stuck in defrost mode (turning button won't change program)
unplug then plun then adjust power lever then it should let you get back into normal cooking power
Aug 15, 2014 | Microwave Ovens
AUTOMATICALLY CHANNEL / VOLUME AND MODE CHANGING
please check touch key board i think it is defect
thanks lal electronics
Jul 15, 2013 | Insignia 32" 720p Flat-Panel LCD HDTV
I am trying to reprogam a remote but the code that came with the new remote does not give me the right code for the tv i am trying to progum it to the name of the tv is broksonic
Most remotes nowdays has a autoscan function. You select this function and place it facing the TV and let it go through all is codes automatically. When reaching the correct code it should switch the TV off. When this happens, you go back a few codes and select the right one.
If you do this and after about 2 minuts nothing happens, chances are good that it does not transmit your televisions code. That is if your multi remote has this function.
Hope this helps you.
Andre
Jul 30, 2011 | Televison & Video
The right signal light stays on and doesn't flash.
Sounds like a worn out flasher, See Auto Zone. The flasher plugs in like a extension cord. Just pull the old flasher off and plun the new in.
Sep 11, 2010 | 1994 Oldsmobile Cutlass Ciera
Need to make it advance automatically
Sure! Not only did Kodak sell an external automatic timer that plugs into the remote socket, a number of other companies had them as well. If you can't find one searching online for "Kodak slide projector plug-in timer", try: www.micro-tools.com Good Luck !
May 12, 2009 | Kodak Carousel 4600 Slide Projector
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
Rca universal remote RCU300TMS
Here is your manual.
http://66.77.167.109/rcaaccessories/docs/man/RCU300T_DOC_OM.PDF
If you want to find the code for your TV, use the automatic code search function on page 8.
Hope it helps!
Oct 13, 2008 | RCA RCU300WBL Remote Control
Remote control RM-810
Try 571. If this doesn't work try setting the code via the automatic programming feature.
RM-810 Automatic Searching
1. Turn on the TV
2. Press the “TV” key (*, **, or **) you want to program on the remote. The light should flash once.
3. Press the “Set” and the “Power” button simultaneously for 2 seconds. The indicator light should stay on.
4. Release both buttons. The indicator light will flash constantly indicating the automatic search mode.
5. After the indicator light illuminates, release the two keys simultaneously.
6. If the controller can turn off the device during its auto programming, you can finish programming in 1.5 seconds by pressing any other button on the controller
7. Check whether operation of other buttons is at normal state. If so yor setting is successfully accomplished.
If you cannot control the functions, try steps 2 through 5 again. If you do not press any button, the auto search function will stop after 30 seconds and the indicator light will go out and you will have to restart the auto search.
Let me know if this works for you. Thanks.
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
18 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
