Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Washer fills wont spin out or drain water
Our washer will not spin out or drain out the water . We found the door lock release thanks to someones previous posting. What is the pipe looking thing behind the little round access door and how do you get to the pump to see if there is a coin or something jamming it?
  • ivan zuniga Mar 16, 2009
    my kenmore washer goes through all the cycles except the spin and it wont dump the water
I had the same problem. After releasing the door and removing the wet clothes, I siphoned the water from the drum. Make sure that the water is turned off and the machine is unplugged, Then I opened the large black cap behind the round white cover on the surface. Be prepared to capture about half galon of water. This is the opening to the drain pump. In my case, there were some toys from my kids which had stuck in the turning part of the pump. I removed them and replaced the cap to the pump. Everything seemed to be OK after that.
I hope that this helps. Please be adivsed that I am not a repair person and proceed with caution and use common sense when dealing with electric appliances.
Good Luck
Posted on Nov 08, 2008
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Hello my splendide wd2000s wont drain or spin and wont release the door lock...what do you think
If the machine senses that there is water still in the tub, it will not release the door. Unplug the machine you should her a click and the door should release itself. should take about a minute. As far as the drain and spin, remove the washer/dryer back and check the drain pump, check that the lint filter is clean and that the drain hose is clear of foreign objects. I have instructions for how to unlock the door when the machine is in a cycle. If you're door lock is continuously giving problems,i can walk you thru the steps to test it, to see if needs to be replaced. Lets start with those solutions first, if they don't work we can go to the next step, which would be to test the drain pump and the door lock, and also to put the machine in diagnostic mode
Feb 07, 2011 | Splendide 2000S Front Load Washer / Dryer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Hi, my washer will fill, agitate, stop and not drain or spin.
Hi everyone, I found the solution to my washer problem. I checked the lid switch and it was ok, but the lid lock was damaged. I opened the lock and I solder it and the problem was solved.
I hope this info can help someone.
May 25, 2009 | Frigidaire FWS833A Top Load Washer
I have a duet f/l loader. The washer fills with water when not on
I FOUND THE PROBLEM WAS THE VALVEWHICH CONTROLS THE WATER INTAKE ON THE TOP OF THE WASHER. I PICKED UP THE REPLACE VALVE IT WAS LOCATED AT THE TOP OF THE WASHER WHERE THE WATER INTAKES ARE. THIS SOLVED MY PROBLEM.
yOUR SITE WAS VERY HELPFULL
THANKS ****
Nov 26, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Duet washer door locked
After pulling the manual door release by removing the bottom door panel you are able to add 1 cap (1 tbsp) of liquid cooking oil to the water. The cooking oil will greatly reduce the amount of suds so you can complete the cycle.
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frontload Washer won't spin or wash.
check the door lock/ latch mechanism
Sep 17, 2007 | GE WSXH208A Front Load Washer
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
405 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
