My washing machine will fill with water and agitate but will not drain to move through rest of cycles.
  • 5,911 Answers
If this is a Whirlpool, Kenmore, Estate, or Roper model washer this is a common symptom of a lid switch malfunction. A lid switch is a very simple and inexpensive fix. The following link explains how to replace one:
In many cases a simple inspection of the lid switch is all it takes to fix it. It could be loose or not making proper contact. Check the mounting screws that hold the switch in place, first. If the screws are loose or missing, that may be all this required to get the switch to line up correctly with the lid strike (if equipped). NOTE: Some washers have a lid switch that is located under the washer rim near the left or right lid hinge. The lid strike is a small plastic piece that is physically mounted to the washer lid. The strike activates the switch through a slot as the lid closes. If the lid strike is broken or missing, this will also cause the same symptoms. If your washer has the other type of lid switch that I described, you can sometimes adjust the hinge rod that activates it by bending it slightly.
You can find replacement parts at Just type in the the model number and you can usually locate what you need under the "Top and Cabinet" heading. A replacement switch generally costs in the neighborhood of $25-$35. A rather inexpensive fix, for what may appear to be a big problem.
I hope you find this information helpful. If you still have questions, please post back with your brand and COMPLETE model number, so I will be abole to assist you further.
Posted on Sep 21, 2008
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Washer fills but will not agitate
When you say the rest of the cycles. make sure it is spinning. That washer will fill up and drain and not agitate or spin if you have broken the couplier between the motor and transmission the motor reverses. tip the machine back and feel right behind the motor for a plastic coupler. In wash check the bottom part of the agitator if its moving and the top is not you will have to replace the doggets in the agittator.
Apr 26, 2010 | Whirlpool LSR5132PQ Top Load Washer
Wahing machine will not wash
the entire agitator is not moving during the wash??? or just the top section that looks like a big plastic corkscrew???
or is the unit actually just filling with water, making the motor running noises and going thru the motions of running a cycle yet not actually moving anything within the unit, then draining out as normal??
if just the top section of the agitator is free spinning instead of ratcheting as normal you'll need to replace the agitator dogs if present.
if however the units just filling and draining of water with no inner movement then more likely the drive coupling is bad and needs replacement..
hope this helps,
best of luck,
Oct 25, 2009 | Whirlpool Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
My GE washing machine is stuck on agiation mode.
Jul 15, 2009 | Washing Machines
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Dec 13, 2007 | Washing Machines
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
