Question about Microsoft Xbox 360 Console
Deleted guest profile
I deleted my guest profile how can i get it back
    Master:
  • 505 Answers
Only way you ca get it back is if you save the profile online or to a memory card
Thanks
Viper:
Posted on Sep 21, 2008
How to delete Guest and get back to my own mail ??
How to delete Guest and get back to my own mail ?? - Fixya
www.fixya.com/support/t26005115-delete_guest_get_back_own_mail
2 hours ago - Help this question get an answer by entering the correct category or ... How do i delete my password on my home screen chrome laptop. Jan 25 ...
PSA: Don't Let Your Friends Sign Into Google On Your ...
gizmodo.com/psa-dont-let-your-friends-sign-into-google-on-y...
GizmodoJun 3, 2013 - Merging your own accounts is one thing, but can you imagine ... I removed my email from the account, but that ended up deleting my entire google account. I thought ... How can I get back my google drive and my google+ account? ... I have a guest computer for friend at my house to avoid anything awkward.
Evite ' What happens after removing a guest? Can...
Dec 12, 2015 | Computers & Internet
Why cant I log into home page?
Normally what I do is this:
Turn on the computer, press F8 a few times
Click safe mode with command prompt.
Type in this into the black box: net user administrator /active:yes
Restart your computer
You will now see an administrator account
Click on it, windows will start normally.
Move over your documents from your old account
Once you have everything, delete your old user account
Voila.
Jul 02, 2014 | HP Pavilion dv6000z Notebook
Accidental deletion of administrator user profile
Can you login as a guest? First try : a system resore/recovery. You didn't give info on the make, model of laptop?
Dec 13, 2012 | Computers & Internet
How to get computer off a tempory profile
which operating system ?
Every time that you log on to a Windows Vista-based computer that is connected to a domain, a temporary user profile is created.
When you log off the computer, the user profile is deleted.
This behavior usually occurs because the account that you use to log on to the computer is a member of one or more of the following groups:
•Guests
•Domain Guests
If this is a school/work computer then this is most likely the way the NetAdmin has set it up.
If this is your home computer then a temporary user profile is issued each time an error condition prevents the user's profile from loading.
You may encounter profile issues if you log on with a user in the Guests group.
You need to remove the user in question from the local Guests or "Domain guests" group and that should do it.
1. Click Start
2. Right click Computer and Select Manage
3. Select Local Users and Groups > Groups
4. Double click Guests
5. Check if the user that is having the issue is a member of the Guests group
6. If so, remove the user from the Guests group
7. Log off the workstation and log back on
8. Verify the profile is now local
or
Try following these steps and check if it helps:
Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly.
Therefore, make sure that you follow these steps carefully.
For added protection, back up the registry before you modify it.
Then, you can restore the registry if a problem occurs.
a. Log on to the system by using an administrative user account other than the user account that is experiencing the problem.
b. Back up all data in the current users profile folder if the profile folder still exists, and then delete the profile folder. By default, the profile resides in the following location:
%SystemDrive%\Users\UserName
c. ClickStart, typeregedit in the Start Search box, and then press ENTER.
Collapse this imageExpand this imageIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
d. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
e. Under the ProfileList subkey, delete the subkey that is named SID.bak.
Note SID is a placeholder for the security identifier (SID) of the user account that is experiencing the problem.
The SID.bak subkey should contain a ProfileImagePath registry entry that points to the original profile folder of the user account that is experiencing the problem.
f. Exit Registry Editor.
g. Log off the system.
h. Log on to the system again.
After you log on to the system, the profile folder is re-created
hope this helps
or
1. Use SFC / SCANNOW command to help you detect and fix any corrupted or missing system files.
1) Go to Start menu, expand "All Programs" - "Accessories" - "System Tools", right-click "Command Prompt" in the pop-up menu, select "Run as administrator", then input "SFC / SCANNOW" without quotation marks and press Enter.
2) When the "SFC / SCANNOW" command is running, this command will scan every corner of your system, and repair the missing or corrupted files.
2. Shift to another administrator user, if you don't have one, please create a new administrator account and log in.
3. Navigate to C:\Documents and Settings folder, backup the data of your original corrupted profile, then delete the corrupted profile and all the temp profiles.
4. Open Registry Editor (type "Regedit" without quotation mark in the start menu blank and open it), search for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\ProfileList, under the profileList subkey, delete the key named SID.bak.
5. Restart your computer; you will be able to log in the normal profile again.
hope this helps
Sep 23, 2012 | HP Pavilion G4 G6 G4-1000 Series...
My hp pavilion g series is loged on to a tempery profile so every time i log off everything is erased
•Guests
•Domain Guests
1. Click Start
or
hope this helps
or
hope this helps
How to login xp after deleting a administrator accounts
Try logging in as Guest,or guest,no password.
Then go to Control Panel-User Accounts-New User and re-establish an Administrator User and account settings for it.
Make whatever User accounts you'll need,and then delete the guest account.It's a security hole.
If this helps,please rate my post.
Thanks
Bob
PS If you need anything else,or have a question about this problem,post back and ZI'll help you out.
Aug 18, 2010 | Microsoft Windows XP Professional for PC
I can't log on as a user but I can log on as a guest or in someone else's name. When I try to log on it keeps starting the window's start up.
This sounds like a damaged profile. Try creating a new one if you can access the computer as an administrator. Then you should be able to salvage data from the old profile...Then delete it.
Aug 05, 2009 | Computers & Internet
My administrator account is corrupt and i can not log into it, but luckily i have the guest account turned on but with this account i can not create a new account like an administrator one. so how do i...
Without using 3rd party pay-for tools, I would recommend locating the Windows CD that came with the machine. I would then boot to the CD, and use the Recovery Console option. When you get into the recovery console, you should be able to log in using the administrator password only. This doesn't load the Administrator profile, it just uses the password for permissions reasons. I would then navigate to the Documents and Settings folder (assuming this is XP) and rename the Administrator profile folder to something else. Once you rename this folder, restart the computer, log in as Administrator again, and Windows will create a new profile for the Administrator, and leave your old one alone. Once you're logged in, you can browse to the old profile and get your files and pictures back.
May 11, 2009 | E-Machines eMachines Desktop PC
Error message: access denied
go to ur control panel and make sure ur not useing a guest profile u must be in a admin.profile to change any files and try deleteing all passwords for ur admin. profile this should fix it
Mar 27, 2009 | Dell Inspiron 6000 Notebook
Xbox live
Make sure that you have an Xbox Live Gold subscription first,
Second You won't both be able to play at the same time enless it is a game that provides guest support(and in some games WITH) guest support you cannot play anything ranked online. To sign in a game with Guest support hit the guide button on the second controller select choose profile and scroll down, if u see "Guest" as a profile and you did not create it, then that game has guest support, and you can both play.
______________________________________________________
If u are just trying to let him play alone then you have to sign him in how you would normally
Jan 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
94 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
