Question about Belkin Computers & Internet
NEED TO MAKE MY SETTINGS PRIVATE AND INSTALL SECURITY CODE.THIS IS FOR A ROUTER
  • 781 Answers
Look in the router documentation.. you, should be able to change the IP address to access your router, just to start..
dependent how good your router is you should also be able to set up a password to access the configuration page... ... bottom line.. look for your router documentation
Posted on Sep 21, 2008
Setting security
Hi Marlene,
Yahoo games use TCP Port 11999 for communication.
Case 1: (If the security settings on the router is blocking)
Kindly forward this TCP port number 11999 on your router to your computer's private ip address.
Case 2: (If the personal firewall in your computer is blocking)
Kindly check the documentation of your personal firewall how to define exception for this traffic.
Note: If you could provide more information of your router and the environment, I would be able to assist you more.
Kindly rate this answer if it is helpful.
Jan 20, 2014 | Computers & Internet
Setting up a new modem
After you press the reset. Your laptop has to be physically connected to the router to configure it
Open your web browser, type in "192.168.1.1" and login using username and password.
In "Basic setup" DHCP Server should be "Enabled"
Enter "Domain name" Name your private network
Set the starting IP address - Enter 10 ( any low number)
Set time zone
Save Settings ( button at bottom of page )
Under Advance Routing, set Operating mode as "Router"
Save Settings
WIRELESS TAB
Wireless - set to MIXED
Wireless network name - same as domain name
Select a wireless channel (default is 6)
Wireless SSID Broadcast - ENABLE
Save Settings
Wireless Security tab
Select WEP
Default transmit Key - select 1
Enter a pass phrase to generate a security code, click on Generate
WRITE DOWN THE PASSKEY ( aka, Security code)
KEY 1 should have this PASSKEY entered.
SAVE SETTINGS
On your laptop, right click on the icon for the wireless on the task bar, select "View available networks"
Select your network, it should prompt you for the passkey, you will need to enter it twice
Jan 08, 2013 | Zyxel (91-004-361002) Wireless Router
Cant set up wifi on my new tablet
To set up your WiFi network, tap the Menu Key > Settings > Wireless & networks > WiFi settings. If WiFi is not checked, tap WiFi to turn wireless on, and wait for your tablet to detect nearby networks. Tap the name of your network and enter a security password, if required.
WiFi networks that are configured as private or closed do not display the network name on WiFi-enabled devices. To Join a closed or private network, tap Menu Key > Settings > Wireless & networks > enter the WiFi network name, security, and password.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 20, 2012 | Linksys WRT120N Router
Upluged router to move it and lost "Secure"
Welcome to fixya
Please follow the steps to make the wireless network private
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts
Thanks
Vote me if you find my suggestion helpful
Apr 25, 2011 | Linksys Wireless-G WRT54G Router
How do you change security code for wireless router xwr100 model bought from private owner and didnt get code
I'm not familiar with that model, but there should be a reset button on the back. It'll be a little round recessed button, the type you need a pen or toothpick to press. Hold it in for 30secs and that should reset it. You'll then have to set it up again to your requirements, use WPA or WPA2 if you can, WEP isn't as secure.
Feb 16, 2011 | Vizio Computers & Internet
How can i find my wep key code for my router
Follow Step # 1 in this guide here. Look for Security settings somewhere in the router menu and you should be able to find the WEP key under there.
Without information on your model of router, we can't be more specific.
If you are still having problems, follow Step # 10, or even 10.5!
Jan 18, 2011 | Computers & Internet
I've forgotten the username and password for my router. The router I have is the DSA-3200. Airport wireless G public/private gateway. Is there any way I can reset the password to default
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Dec 29, 2010 | D-Link AirSpot DSA-3200 (F56772) Firewall
My router is 2 years old and yesterday, i started to get the message saying i am not connected to the network. Does that mean the router is no longer working ?
What is giving you thisw message? If it is on a laptop, accessing router wirelessly, then (on the laptop) go into Network Settings and verify that your computer is set up to use a Private network, as Public networks may not let you see other computers on the network. If it is set to Private, then your router may have stopped working. Try resetting the router by sticking a paper clip into the Reset hole, which resets the router to Factory Settings. Go ahead and connect to the router with a CAT-5 cable and use IE to go go to http://192.168.1.1 and complete setting (simplified) as follows:
In Wireless Section, Choose your SSID (Network Name), set security in the section below that by choosing security method and passcode. This passcode MUST be used by all users to access thev wireless signal. Let me know ( jaye.ellen@gmail.com ) if this does not help.
Dec 17, 2009 | NetGear RP614 Router
Need security code numbers in order to install..usr5461 1.1
Are you looking for the wireless security key / password ?
That is set up on the router.
These are the settings of your router. To find out the code you will need to access the router set up interface.
Do you have any computer connected to the router or able to go online through the router ?
Use that computer to open the set up of your router.
Click Here for more info
Nov 13, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
I need help setting up security.
By default, your router will grab the first IP address on your private network. This address is usually 192.168.0.1.
Navigate to that address in your browser and it should pull up the login page to the configuration portal. By default, credentials to login are admin/admin. Once logged in, you should change that password right away.
Then you may change the security settings on the router according to instructions that should have been provided. Usually, configuration will include access control lists, hiding your SSID, and creating a secure network password.
Aug 08, 2009 | D-Link DIR-628 Wireless Router
Computers & Internet Logo
24 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
