Question about Dell OptiPlex GX260 PC Desktop
I tried the process
Techgem,
I tried your Bios process however the system still stops after safe mode spash screen comes up(where you have OS ver info at the top and safe mode on bottom corners). But only the mouse shows and I can not do any other interaction. When I went into the Bios there is no default it is only the Dell standard info.
**** u all u basterds am not having money to pay
Posted on Sep 24, 2008
How o i get out of safe mode?
BIOS menu at power-up.
Depends on computer motherboard.
All PC's need a certain key to be pressed as soon as computer starts up to enter into the BIOS menu.
This may be F2 function key or DEL key.
Some BIOSes require function key F8 for safe mode option.
Yours may be different.
In the menu, you should look for SAFE mode.
DO NOT ALTER any other settings.
This controls the heart of your computer, wrong settings can cause major computer headaches.
So in order to offer more help, more detailed info is needed.
What make and model is the computer?
Can you supply the startup BIOS details?
Usually, as the PC starts, a small message appears at the bottom right of the screen.
This should show the BIOS version.
An example AMI Bios ver 9.01
Otherwise you can download a free app called CPUZ then run it.
CPUZ will generate a report of your PC hardware.
Nov 18, 2017 | Computers & Internet
Blank Computer Screen
First I will suggest you to Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including Black screen
After that restart your computer in safe mode by press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode
Inn safe mode Update your graphic drivers from your system manufacturer site
If this is helpless then simply get Reginout that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors.
Hopefully it will help you
Jun 24, 2013 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
Sony pcv-rs520 boot bios - need BIOS entry key for changing boot drive
Should be the F2 key to enter setup. Make sure you are pressing this key during the VAIO spash screen on boot. If you press it after the spash screen the bois will not load and you will have to power cycle the computer to get the spash sreen back and try again.
Feb 20, 2012 | Computers & Internet
I have a presario c500 that comes up to the f10 and esc screen upon booting, and then will go blank and continue to loop though the screen again and again. I have removed the battery and held the power...
It is your operating system that is failing, not your hardware. When Windows hits a Blue Screen of Death on startup it happens so fast that you only see it for a split second then it reboots. If you want to know what the issue is, when it reboots wait till the first screen goes away, (the f10 and esc screen you mentioned) then start tapping F8 every few seconds. It will bring up a new menu that has options like Safe Mode, Safe Mode with Networking, etc. Choose "Disable Automatic Restart on System Failure" then hit enter. Windows will continue to boot and then will stop on the Blue Screen of Death. Copy down the info on the screen and enter it into a Google search or post on here for me to diagnose. Let me know if you need more help.
Aug 10, 2010 | Computers & Internet
Wont do any thing comes to blue screen and has this Tech info ***STOP:0x0000c1f5(0x00000000,0x00000000,0x00000000,0x00000000)
you can try and go to safe mode by pressing F8 continuously before windows loads and then selecting Safe Mode using the UP or DOWN arrow keys... if it doesn't boot up then you need to reinstall the OS or use the recovery disc that came with that laptop...
Nov 08, 2009 | Acer TravelMate 2480 PC Notebook
Blank screen problem
hi,
1.Please keep pressing and releasing F8 key when ACER logo is coming.
2.start the computer in safe mode by selecting it in advanced OS choice menu.
3.If started in safe mode go to programs>accessories>system tools>system restore and restore the system to a back date by selecting a bold previous date in calender.
Idf not booting in safe mode also you may need to reinstall the OS again.
Jul 06, 2009 | Acer Aspire One PC Notebook
Blue Screen c000021a
Next step is remove hard drive and see if it is recognized in another computer. The Hard Drive could just be bad, but you need to rule out the motherboard drive controllers that could also be bad. Also try a known good drive in your system.
Char S.
May 27, 2009 | Dell Vostro 1510 Laptop Computer PC...
Long POST and will not mount HDD.
first of all, you need to another 512Mb of memoires. it will run better. second, go to BIOS and search for boot order, chaneg the the boot order to Hard driver first.
May 01, 2009 | Computers & Internet
Emac stalls on the OS X start-up
Start here...   Resolve startup issues and perform disk maintenance with Disk Utility and fsck  Mac OS X: How to start up in single-user or verbose mode  If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...   What is Safe Boot, Safe Mode?   Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack  Another excellent free tool for performing maintenance is Onyx (be sure to download the right version for your system). Install the package, then run it, it will check your drive and the structure, after this, click on the automation tab and check on everything for Maintenance, Clear Cache, Cleaning, and check on Reset -> LaunchServices database and Mail's Envelope Index. When it completes, restart. Repeat any time something seems flaky, if not try to run at least once a month.
Feb 01, 2009 | Apple eMac G4 Desktop
How do you change the packard bell splash screen @ the bootup process. can you edit your own pic
i dont think that you can edit you own pics it depens on what os you are running . is the splash screen your screen saver or what more info on the spash screen
Aug 18, 2008 | Packard Bell Computers & Internet
Dell OptiPlex GX260 PC Desktop Logo
20 people viewed this question
Alun Cox
