Question about LG WM2487H Front Load Washer
Holes in Shirts from LG Front Load Washer
We've checked the inside of the washer and there are no snag points. Are there any other possible solutions to this problem (other than putting the shirts in a mesh bag or pillow case)? Could it be the rollers.
  • 489 Answers
This may sound weird but try using a slower spin speed.  The reason is because the faster the spin speed is, the more the clothes can get sucked through the holes in the drum.  On the other side of the drum that you don't see could be some metal points that can snag the material.  When you pull the clothes out, you will pull the thread that comes entangled with those metal points.
Posted on Sep 29, 2008
2 Suggested Answers
SOURCE: Holes in Shirts from LG Front Load Washer
I have the same problem. It's not zippers or bra hooks. You have to first check the rubber barrell in the machine. Sometimes little odds and ends get into there from pockets. Second, you have to pull open the tiny door on the front bottom and drain the stupid thing on a regular basis. Be prepared- a LOT of water comes out. And even if you use a bowl, the machine is designed well to hold the water that comes out. After that, you have pull the hose next to the drain out and unplug it. Even more water will come out. I usually find some nasty thing in there that is the culprit. I hate this machine. It has destroyed just about everything I own.
Posted on Sep 21, 2009
Own a lg wm1832cw front load washer doesnt seem to clean properly when wearing tee shirts for an hour smells like they never were washed paid alot of money for this thing seems cheaper top load machines...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Sep 12, 2011 | LG WM1814CW Front Load Washer
I am finding tiny holes in the sleeves and fronts of random cotton shirts. i had an exterminator in and he could not find one bug in my entire house. is it possible it is washer or dryer related? it's...
Check for any small pieces of sharp metal in your washer tub on the front and back where the tub has a seam and is welded together. (you will need a flashlight and will have to put your head inside the washer to see this.) Check very carefully it could be very small. I have seen the stray metal welded into the tub and the tub would have to be replaced. Also check your dryer for anything sharp or holes in the front and back seals. Please rate this post.
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It it the button on your pants or jeans!!!!!!! Test it out
May 07, 2009 | Maytag Neptune MAH6500A Front Load Washer
Holes in Tshirts
loose agitator?take a towel and run it around inside of washer as if wiping it out....see if it snags anywhere,wipe around on agitator also to see if towel snags on anything.lift up on agitator to see if loose,should only move up and down about 1/8 inch. thanks Fame !
May 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer making holes in clothes
Feel the drum inside for any sharp object example a pin that is sticking sideways in a hole or the the drum spot-weld spots that came lose making a high spot.
I did find the same kind of a problem with a Defy front Loader machine. You can also check the gap between the door and the drum lip.
Hope this will solve your problem and save yourself from spending big bucks on new clothes.
Clive
Apr 17, 2009 | LG WM-2277HW Front Load Washer
Tiny holes in clothes
We have the same problem. Look at the agitators inside the washer. We found strings and material there. Not sure what or if there is a fix bout I just saw the problem 2 days ago.
Aug 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE Front load washer clothes coming out with holes/torn/even shredded
Metal inside washer drum may be faulty and causing tearing of clothes (run your finger around the inside when empty and you will feel where it snags). Had same problem, only got worse and ruined many expensive t-shirts! Replacement of drum is required and is extremely costly if not under warranty!
Jun 05, 2008 | GE WSXH208A Front Load Washer
Fabric pulls on gentle cycle
Check the inside of the drum to see if there is any loose vanes.  Then check the holes in the drum itself to see if there is any protruding metal shavings that is causing the problem.  There should be no rough edges at all.  It sounds like the drum is the problem.
Apr 15, 2008 | LG WM-1832C Front Load Washer
Holes in clothes
run a old hosiery or cotton wad (like from holloween) around the inside of the drum. see where it snags,
the drum is warranted for a very long time. (don't know exact)
Mar 26, 2008 | Kenmore Elite 45986 Front Load Washer
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
LG WM2487H Front Load Washer Logo
753 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
