I have a Royal educator electric typewriter which is not operating. I took the casing off and found that the pulley which is connected to the motor and wheel was broken, other than that it is in perfect running order. I can not find a replacement pulley, can you direct me to site where i can purchase pulley and a ribbon. I know it is a trivial part, but i love it. It is just the right size for the space i have. Any help would be greatly appreciated. Thank you very much; Bill
  • 186 Answers
SOURCE: The ribbon is no longer printing on the tape.
are you sure it uses a ribbon? Or does it use an ink roller. If it uses a ribbon it should reverse by it self. Make sure it is installed properly, there is not a ribbon reverse switch it should do it automatically. if its installed right.
Posted on Jun 17, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Typewriter suddenly will not print!
It's been awhile since I've worked on these.
What is the typing mechanism in here? I believe Brother was using a wheel.
Posted on Jun 19, 2008
SOURCE: Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Posted on Jan 27, 2009
  • 10865 Answers
SOURCE: What size a step pulley required for the motor ?
rpm_chart.jpg?t=1236890602
here is the chart you need to answer your question. please mark this as a fixya! thanks
Posted on Mar 12, 2009
  • 3594 Answers
SOURCE: How to load ribbon and rewind ribbon.
The ribbon should reverse itself if it working properly. Just to the indide of each ribbon is a reversing that the ribbon should go thru, Move that arm away from the empty spool and type a few letters it should reverse. DickyO
Posted on Jun 11, 2009
Broken drive belt on royal aristocrat portable electric typewriter
Looks like almost none of those answerers even read the question.
Aug 26, 2012 | Royal Vintage Aristocrat Portable...
One of the linkage bars for the type bar is missing on my Royal KMM Typewriter
Depending on the size of the holes in the type bar you can make one from a thick paper clip or swap one from a little used key like ; or 1 (you can use lower case L) This isn't a perm. repair.
DickyO
May 23, 2012 | Royal Office Equipment & Supplies
Need new motor
I don't know why you think it needs a motor. There are 3 motors carrier, ribbon lift and paper feed I have never replaced any of them. Before you do put some WD40 on there bearings and lube the silver shaft that the carrier slides on and the carrier pulleys.
DickyO
Mar 07, 2011 | Royal Satellite 40 Typewriter
TA Royal 420 (Electric Typewriter)
I dont know where uou can find one try e-bay
Jun 12, 2008 | Office Equipment & Supplies
BROTHER TYPEWRITER
Is your typewriter made by Royal or Brother? I think your question was mis-posted under Brother as opposed to Royal. IF your machine is a Royal, Brother will NOT be able to help you. THIS GOES FOR EITHER MANUFACTURER...Have you inspected the platen drive gear? Is it cracked, missing teeth or otherwise damaged? If not look on both sides of the typewriter for the drive motor. Look to see if the gear mates with the motor.
Jan 23, 2008 | Royal Satellite 80 Typewriter
29 people viewed this question
k24674
jasbo
jasbo
