Question about HP OfficeJet 6110 All-In-One InkJet Printer
Start up problem with printer
I've had my printer for a couple of years and have never had any problems. Tonight it start making a grinding sound and I got an error message "Scanner failure. Turn power off then on again." I wasn't trying to scan anything, and I've turned the power off and on again several times. Always the same thing -- this heaving, grinding noise that lasts for a couple of minutes, then I get the same error message. I don't think the machine is kaputt, because I've got my phone hooked up through it and I'm able to get a dial tone (the line goes to the printer, then a line from the printer goes to the modem. The whole problem when I hooked up a new phone, but I don't know why that should have caused an upset -- the DSL filters were undisturbed. Can anyone offer any help?
  • NeoNon Sep 22, 2008
    Yes, a grinding noise as if the carriage is trying to move, but is stuck, or something.
  • Anonymous Sep 28, 2008
    Yep! Same problem. Started about the same time I hooked up my DSL.. Makes a "god-awful" grinding noice as soon as the power is turned on and I get a scanner error message and then a "turn off power" and restart message but it does the same thing each time. Can anyone help?
  • 21 Answers
Your scanner glass is get dirty and all scanners make a self diagnostic program when we turn on the printers.
At this point, you will hear a little noise from the scanner carriage lamp, witch is doing self calibrating. In this calibrating time the scanner unit "read" the white and the black levels, and the white (in your case) is not white, is quite gray because is dirty.
The solution is a very simple, but require much skill.
You must disassembly the scanner unit, remove any screw you see (you need an no. 2 phillips screwdriver) and very gently remove the upper side (with glass) from the rest of scanner unit. Please note that is several plastic fasteners to be disposed.
after you remove the glass (with a plastic frame) you get a small tissue of cotton and soaking with an windows cleaner solutions. Gently clean the BOTH surfaces of scanner glass.
For assembly follow the reverse procedure.
Beware to the glass, it has only 3 mm thickness. Don't broke!
Like I sad: simple problem, but require much skill. If you think is to difficult for you, please go to the service.
Posted on Sep 24, 2008
We bought a Samsung DV419AV dryer less than a year a go. tonight my wife went down to dry a load of work close for tomorrow and set the drying cycle and pushed the start button. you can hear a hum but the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Dryers
When I start my truck it makes a grinding sound like the starter is stuck on the fly wheel. I have to try to start it a couple of times before it will actually turn over.
hello there i would suggest that it sounds like the starter is going out and would replace it soon before you tear up the fly wheel this should solve you're problems hope this helps you out...
May 19, 2010 | 1994 Chevrolet S-10
I have a epson artisan 800 I'm tring to fax from the automatic feeder but it keeps making a grinding sound and then it says paper jam but paper never even went through
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Jan 02, 2010 | Epson Artisan 800 All-In-One InkJet...
Makes grinding noise especially when shutting down
a grinding noise in a dryer is usually due to a broken motor coupling. Not sure however since you didnt include a model number, brand or year the machine was purchased. If you own a somewhat older model (bought from 4-6 years ago) it is most likely the motor coupling however newer models can have some other problems and usually require a service tech to come and look at.
Dec 24, 2009 | Dryers
Kenmore Washer Grinding Sound - No spin or agitation
sounds as if oyou have a bad motor coupling, you can search you tube for keywords, whirlpool motor coupling, far easier to watch someone perform the repain that try to explain it, easy to do!!! part number 285753
Feb 23, 2009 | Kenmore 24032\24036 Top Load Washer
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
Makes loud sounds
I had the same problem with the loud grinding sound. The gears on the cartridge(s) is not turning but rather stripping creating a grinding sound. Reinstall all of the toner cartridges. If that doesn't work, pull each cartridge out and manually turn the gear on the cartridge. If the problem persists, you may need to purchase a new toner cartridge.
Dec 04, 2007 | Brother MFC-9420CN All-In-One Laser...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
98 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
