Question about Dell Latitude D620 Notebook
Three LED's flashing
How did you solve it? Mine is the same ...
Cpu was not locked in. last tech didnot screw it locked
Posted on Sep 27, 2008
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
My samsung hlr6167w will not power up. It sounds as though the lamp is trying to strike, however it never does come up on a picture. After several minutes, all three lights on the front power cirle (Lamp,...
All three LED lights flashes,u hear alot of clicking sounds too?Yes,ur tv the Ballast board is dead too.This Ballast board job is only to ignite the tv projection lamp only.Replace the Ballast board,should solve this problems.
Apr 17, 2011 | Samsung HL-R6167W 61" HDTV
My sharp Aquos LCD TV LC37D44U while watching TV suddenly witched off. Both the power led light and the OPC led light together started to flash twice, and then only the OPC led light three times, then...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem......
Jan 27, 2011 | Televison & Video
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Volume trouble
The top button on the control surface, the one with the green flashing LED, is the volume control. When the unit is "ON" pushing the button up or down raises or lowers the volume, simple. When you connect it to the charger that same green light will turn red while charging. If you push the top button forward (up) at the same time you press the lower button (power) the LED will flash 1-3 times. Three flashes is fully charged and one means it's getting low.
This is a great head set. I just sat on mine and broke the ear piece. I'm looking for another as we speak! It's worth more than it's current retail price by far!!!
Jan 27, 2009 | Body Glove Earglove Bluevoice Bluetooth...
Samsung DLP HL-S5087W 56" Confused...
Mine did that when the color wheel didn't spin up...just give it a whack where you installed the light & the wheel should spin up. I had to replace my color wheel as the bearing was shot & was buzzing all the time. The light won't come on if the wheel doesn't spin up first.
May 08, 2008 | Samsung DLP HL-P5663W 56" TV
Panasonic problem
Convergence board needs to be replaced. A qualified technician should be able to fix it. Mine cost $180 to fix
May 04, 2008 | Panasonic PT-53WX42 53" Rear Projection...
WF320P Water fills on wash cycle drum starts to rotate. After 30 seconds or so middle three red error lights flash and cycle stops.
Hi there swamib lets see if we can help you out. If the lights in the middle of the appliance flash led 1,2,3 that means there is a problem with the heater it is most likely it is open circuit replace this and it should solve the problem keep in touch noffie......
Apr 08, 2008 | Washing Machines
My K750i Key pad Lights are not working
mine does that aswell i went into the o2 shop and they said that some little LED light had blown
Aug 06, 2007 | Sony Ericsson K750
Dell Latitude D620 Notebook Logo
51 people viewed this question
Alun Cox
