Technical support MP3 2GB player will not turn off
    Genius:
  • 3,422 Answers
HI,
Please do a soft reset to your player by holding down the power button for 30sec.
Once you have done that your player will turn off.Insert the USB cable and connect it to the PC and allow it to recharge then press the power button again,it will turn on and you will not face this problem again.
Let me know the result.
Posted on Sep 21, 2008
    Master:
  • 726 Answers
Since the button to turn it off is the same as turning it on it might be faulty and not reading i no there hard to open them but if u can take the battery out and see if it turns on if it does not it will be the button
also check if it is not on lock
When i turn my technics cd player all i see is error
Technics CD Changer SL-MC400
The ERROR Is Cause By The Belt Drive
Remove The Cover And You Can See if
The Belt is Lose or slip of In Any Case
You Must Change That RUBBER DRIVE BELT.
Dec 31, 2013 | Technics SL-MC400 110-Disc CD Changer
Technics sl mc409
Loading mechanism is out of aligment. Would need to be taking apart and realigned - something best performed by a pro.
Dec 31, 2013 | Audio Players & Recorders
My technics SLMC6 has a message running saying 'checking discs' and it will not do anything else.
Drive mechanism failure. My Technics unit had a similar problem which turned out to be drive belt failure.
Dec 07, 2012 | Technics SL-MC6 CD Player
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
Technics sc-dv290
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Oct 26, 2008 | Technics SC-DV290 System
Sansa mp3,2gb
Make sure you have the software that came with it installed.
Other methods:
Use Windows Media Player to transfer files.
Open My Computer Open 'Sansa', If you can view your files; you can drag new ones in.
If that didn't help reply with more info
Good luck, please rate.
May 10, 2008 | SanDisk Sansa Clip MP3 Player
MP3 player
Try holding the [POWER] button for about 25secs. and it will turn off. It should work after that. :)
Jan 25, 2008 | Insignia NS-DV2G MP3 Player
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
44 people viewed this question
 Grubhead
Grubhead
