Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Blinks 9 Times
I have the same problem as many others on here. My television blinks 9 times when I attempt to turn it on. I attempted to order the part from partstore.com and they ended up canceling my order because they said it was on a national back order from the manufacturer. Is there any other place that might carry the G Board that I can purchase?
Call sony direct, they will send a fax telling where to send board for repairs. $55.00 plus tax and shiping. It takes awhile to receive fax, I waited six weeks.
Posted on Oct 29, 2008
  • 2,326 Answers
You do not need to replace the entire assembly on this TV. Read the info posted in the link below from another member that was able to fix his TV with the same failure as yours:
http://www.fixya.com/support/t940029-sony_kp_57ws520_standby_light_9_blinks
Good Luck.
Posted on Sep 21, 2008
Kdf-e55a20 red blinking light
Altho you do not say which light is flashing red , you have a light on the front that is for the lamp ONLY...
If you do not have the user manual , get it here & start on page 11.:=>...
http://www.retrevo.com/...myTrevo.jsp?page=man
Jul 06, 2015 | Sony KDF-E55A20 55 in. LCD Television
Panasonic Plasma TC-50PU54 LF21030116 Power light blinks 8 times When I attempt to power on it turns on for split second then shuts down. Is this fixable? thanks.
Yes. It is probably a problem with the internal power circuitry. Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Panasonic Televison & Video
SONY 32 INCH TRINITRON
  1. Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative). ( blinks of standby light to Sony CRT based TVs denotes this. Check this link, if you wish to know more.
If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Jan 17, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
50 inch panasonic viera blinks 9 times no power
That's a error code but its different for various models. I will need the model number of the set in order to let you know what the 9 blink error indicates for your model Panasonic.
Jan 10, 2013 | Televison & Video
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Won't turn on
Capacitors in the power supply section. Same area where your power chord is soldered to the board. Be sure to discharge the set before attempting to work on it. High voltage kills. Good luck and stay safe!
May 24, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
NEC PX-60XM5A 8 Blinks
Overheating issue. Check your power supply board.
May 23, 2009 | NEC PlasmaSync PX-50M5A 50 in. Television
9 blinks
D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
Jan 05, 2009 | Sony KP-46WT520 46" Rear Projection...
Tv wont turn on
have a tech replace the D board 1st if that doesn't solve the problem replace the P board 2nd. both of these boards require authorization to order so an authorized panasonic repair must do this repair.
Jan 05, 2008 | Panasonic TH-42PX60U Television
The stand by timer flash 9 times stop and start again
you have a regulator problem my friend in the power supply or there is a fault in the G board. This is not a repair an untrained person should attempt, please get a pro to assist you in this repair.
Jun 05, 2007 | Sony FD Trinitron WEGA KV-32FS320 32" TV
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
