Question about Emerson Smartset Clock Radio
Time Projector problem
For some reason my time projector only works part time. It worked fine for a few months but now is only on at random times. Is this a faulty unit? or is there a way to fix this?
  • Therapy07 Jan 20, 2009
    Same here. Mine worked for several months and then last night it quit.
    Is there a way to change the bulb?
  • 814 Answers
The reason these projection displays have problems is usually caused by over expanded solder joints. This is caused by heating in the circuit,through prolonged use. This causes the metal in the solder joints to expand. This expansion will eventually cause the joint to loosen. The join because of the combination of expansion and vibration eventually loses contact with the circuit board connection.The problem is usually easily repaired by resoldering the cold solder joints. This type of problem occurs in all types of electronic devices. When this type of repair does not fix the problem, it is because during the process of becoming faulty it has taken it toll on other circuitry in the circuits of the leds. This is usually the power supply circuit for the leds. This will require the replacing the defective components, like transistors and ic's. This is usually best handled in the service centers. They will have all the service information and parts for the repairs. The customer support telephone number for Emerson is 1-800-898-9020 you can call them between the hours of 9am-5pm CT. Give them the make and model number of you Clock/Radio and ask them for assistance.I hope this information has help you understand the reason for the problem with your Clock/Radio. Thank you for using FixYa and have a nice day.
Posted on Jun 13, 2009
Why is my fan not spinning on start up?
You need to replace that fan motor, the bearings are shot for the shaft.
Oct 27, 2016 | Office Equipment & Supplies
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
Red Light flashing
it may be because of the problems as u described air filters and fan .but try first with the filter,u can find it at amazone or flipkart
May 03, 2017 | Epson Computers & Internet
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
I just did it, I took the filter out and then I cleaned it. After that all I did was reset the lamp and filter times which were at 160 for me, and now it works just fine. if the bulb goes out then maybe its time for a new lamp =(
Mar 26, 2009 | Eiki LC-XE10 Projector Multimedia...
Intermittent switching off
Try to provide better cooling for the projector.
1. Check the ventillation for the hall
2. Check the cooling air circulation fan
3. See whether anything is blocking the air supply
Verify loose connection of power cable.
1. Check the cable outlet
2. Check for damage of power cable
See whether any message is displayed before switching off
1. Search on the error message
2. Try getting help on the error ID
I hope, this solves your problem
Have a nice time
Nov 04, 2008 | Sanyo PLC XU35 Multimedia Projector
HC 1500 skewed image issue
Hi there
I've worked on a few Mitsubishi's in my lifetime and one of their most common problems is the DMD Board that goes faulty and this makes the image go all pear shaped.
If you've only had the unit for 3 months now it should still be under warranty and the warranty covers these kind of repairs.
Hope this helps you !
Mar 26, 2008 | Mitsubishi HC100U Multimedia Projector
Works for a few months?
Is this a new device -?
Check with seller and or makers help site.
Lamps guaranteed for 90 days and Machine for 2 years usually
Jan 15, 2008 | NEC VT465 Multimedia Projector
XG-C50 Problem
Replace the fly-eye lens of projector.
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Projector randomly shuts off
hi CLEAN IT!! all these things leads to 1 conclusion: the device is packed with tons of dust it has a safty powerdown on heatup,m4858,gm38/Sanyo-PLC-XP41-Multimedia-Projector.aspx good luck
Apr 06, 2006 | Sanyo PLC XP41 Multimedia Projector
Emerson Smartset Clock Radio Logo
338 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
