Question about Sanyo Televison & Video
Sanyo TV TV only getting 13 channels when I scan channels. I have expanded cable
  • 70 Answers
Check with your cable company some channels are switching to digital already and if your tv is analog it wont pick them up. tell them you want a box and you wont have this problem. i know you ddont want to pay extra for the box but come febuary no box no tv so best get it overwith now sorry its sucks i know
Posted on Sep 21, 2008
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
How do I run a channel auto scan?
There are many different ways, because each TV manufacturer calls each menu option something different. In your TV menu there should be an option that says Set Up, or Channels, or something similar. Your TV should be, Menu, pan right to Channel, select whether you are using Air (air meaning antenna, picking up channels that are broadcast free over the air) or Cable (only if you use cable with no box). Then the option below should be auto scan. Allow to run completely. Sanyo DP42D24 User Manual Channel
Apr 06, 2015 | Sanyo DP55D44 55" 1080p 60Hz LED HDTV
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
Can only get channels 27 and 52 on sanyo 50in tv
is this TV connected to a cable box or satellite dish........if so turn the TV to channel 3, and make sure the source (also on the TV) is set to Cable not AIR... the cable wire from the box / dish is going to the TV (in)
no cable, no satellite how about an Antenna... using this format the source must be AIR and you must let the TV SCAN to lock in all the broadcast channels ... (using any other method there is no need to scan for channels you will only be using one (ch 3)
Dec 20, 2010 | Televison & Video
Program an old sanyo tv
You need to go into the menu and set it for cable insted of air/tv. The television is only getting the 2 - 13 because on that setting, its as high as it goes.
May 20, 2009 | Sanyo DS31590 31" TV
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
New dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
Dec 24, 2008 | Sanyo DS27820 27" TV
Sanyo DS 31520
make sure your got the right cable mode selected through the remote or autual switch on back of tv. if not it youll only see cable channels up to channel 13 that means in is standard tv mode or air. once you selected cable ...run autoprogram and it find all the channels for you. these newer sets, dont bother with looking for a cable switch, its all done automaticly when you hit that autoprogram button but it would be in the menu under setup.
Sep 06, 2007 | Sanyo DS31520 31" TV
TV problem
Are you using cable to get the picture? If you are, make sure the TV set is in the cable mode,If it is then you most likely have a bad tuner in your set. Good Luck
Mar 21, 2007 | Sanyo AVM-1306 TV
Televison & Video Logo
273 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
