Question about GE 29267GE3 Corded Phone
My phone will not remove VIP numbers
My phone is displaying 2 calls. When I go to remove them they will not erase. When you look at the caller ID it says VIP. How do I erase them?
Unhook the phone and take the batteries out for about 3 hours...that will clear the memory.
Posted on Feb 09, 2010
How do I hide my number when calling from alcatel onetouch in australia
here you go
  • How to display or hide caller ID on my ALCATEL ONETOUCH ... support.bell.ca > Bell Mobility How to display or hide caller ID on my ALCATEL ONETOUCH Idol 3. ALCATEL ONETOUCH Idol™ 3 ... Caller ID allows you to hide or display your phone number in ...
  • Caller ID: ALCATEL ONETOUCH Fierce ' T-Mobile Support support.t-mobile.com > T-Mobile Support Learn how to use the caller ID on the ALCATEL ONETOUCH Fierce™. ... press the Phone icon. ... Hide number; Show number;
  • Can I hide my number while calling someone? ' T-Mobile Support support.t-mobile.com > T-Mobile Support Can I hide my number while calling someone? Log in; Home: Account: Billing: Coverage: Devices: Plans: Contact Us: Manage ... Caller ID: Alcatel ONETOUCH ...
  • Jul 04, 2016 | Alcatel Cell Phones
    How do i make my phone number visible to my callers when calling from a Vtech phone
    Caller ID
    If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
    Call block
    If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
    Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
    How to get caller id for missed calls for Panasonic kx-t7730
    Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
    in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
    System Programming:
    1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
    2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
    3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
    4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
    5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
    6. Get out of system programming. (Press Hold or End, then Program.)
    Phone Programming:
    1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
    2. At each phone where you want to log all calls, press intercom, then 7382#.
    User Tips:
    • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
    • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
    • You can erase the entire Caller ID log by pressing Intercom, then 70**#
    • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
    • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
    • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
    Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
    I am having a problem with my Panasonic KX-TG6442t. It won't store phone numbers and is not show numbers on the display when the calls come in. It just says incoming call. When I go into look at the...
    Welcome to Fixya
    Try to erase your phone's voice messages. Press ERASE 2 times while the phone is not in use. Caller ID is being activated by your phone provider. To use Caller ID features, you must subscribe to a Caller ID service. Contact your service provider/telephone company for details.
    Thank you for using Fixya!
    Jul 12, 2011 | Panasonic KX-TG6442T 1.9 GHz Twin 1-Line...
    NO MANUAL HOW DELETE CALLERS IN LOG ?
    You can download the owners manual in PDF format from this link.
    412CID 4 Line Telephone
    To answer you question - From the owners manual:
    Erasing Caller ID Records
    In order to delete a specific Caller ID record in the log:
    1. Using the [<] or [>] key, find the particular record you would like to delete..
    2. Press the [ERASE] key. The LCD display will indicate that the record has been deleted.
    3. You may erase all caller information records simultaneously by pressing [ERASE] from the summary
    Call ID display.
    Hope this Helps.
    Sep 25, 2009 | Bell BE-412CID Corded Phone
    Is there a way to look up previous calls?
    There is only a limited numbers of previous callers
    in a phone, since this is automatically erase as
    programmed. The answer to your question is yes,
    if and when your caller is not yet erased. You can inquire your telephone company, how many callers can your phone hold, before it is erased.
    Sep 21, 2009 | Nortel T7316E 2-Line Corded Phone
    UNIDEN TRU8888-CALLER ID DOES NOT WORK
    Hi
    Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
    If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
    When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
    When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
    You may receive any one of the following messages:
    When a private name is received; Private Name
    When a private number is received; Private Number
    When a unknown name is received; Unknown Name
    When a unknown number is received; Unknown Number
    When invalid data is received; Incomplete Data
    The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
    Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Aug 16, 2009 | Uniden Cordless Phone
    2 Problems: #1Volume fades out. #2No caller ID on Call Waiting
    1. move closer to base
    2. you must have call waiting ID for that to work at all and most of these phones don't use it during active calls.
    go to page 21 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
    Feb 05, 2009 | Panasonic KX-TG1033S Cordless Phone
    I can not get my messages that are stored in the phone. Model # t2326. Cordless 2.4GHz technology
    That model has Caller ID/Call Waiting and stores 30 calls. I f the caller ID does not display when the phone is ringing, assuming the display works, report to the local phone company. Make sure they have you turned on for caller ID service. If the calls are displayed when it rings but cannot be retrieved later, the phones is defective or they have been accidentally erased.
    Aug 23, 2008 | Vtech Lands Phones
    Area code
    Here is a link to the site containing a pdf manual link and this is an excerpt for you :
    Long Distance calls and Area Code Setting/Cancellation
    While the present Caller ID information is displayed, pressing */tone/< will place
    or remove the prefix "1" in the display to set the call for a long distance call, or
    pressing #/> will set or cancel an area code (see page 30).
    Storing Caller ID messages in the Phonebook
    Messages shown in the Caller ID list can be stored in the phonebook. The phone
    number and name of the party on the Caller ID list can be stored in memory.
    1) When the phone is in standby mode, select the Caller ID message to be stored.
    Then press the STORE soft key on the base or the EDIT soft key on the handset.
    From the handset, then select E D I T ?. S t o r e / E d i t N a m e appears. If the Caller ID
    message is already stored in memory, you will hear a beep and T h i s d a t a i s
    a l r e a d y s t o r e d ! ! appears. The number will not be stored.
    2) To complete the setting, follow the steps 3-8 in "Phonebook (Storing Phone
    Numbers, Names, Distinctive Rings, and Speed Dial)" on pages 42-43.
    Dec 17, 2007 | Uniden TRU8885-2 Cordless Phone
    GE 29267GE3 Corded Phone Logo
    108 people viewed this question
    Top GE Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a GE Lands Phone Expert? Answer questions, earn points and help others
