Question about Samsung P520
CLOCK DISPLAY how do u change the single display
I have the same problem!¬
Posted on Oct 31, 2008
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
Nov 10, 2016 | 2007 Pontiac Torrent
Control panel
The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Jun 18, 2013 | Maytag 30" Built-In Single Electric Wall...
Have a Jenn_Air WW30430 - display is barely visable. Can you tell me if changing the capacitor will work?
HI,
You have an LED display, changing anything other than the clock would not fix your problem. I am assuming you oven get daylight directly on the screen as well. Direct daylight can speed up the process of a fading display also...
Hope this hopes
Jul 28, 2011 | Jenn-Air 27 in. Electric Single Wall Oven...
How do I reset the clock on a 2008 Impala, and 2008 Accord? I can't find the manuals
For the Impala:
AM/FM Base Radio with a Single CD Player
This type of radio has a H (clock) button for setting the
1. Press the H button until the hour begins flashing on
display. Press this button a second time and the
minutes begin flashing on display.
2. While either the hour or the minutes are flashing,
turn the f (tune) knob, located on the upper right
the tune knob, you can also press the SEEK arrows,
\FWD (forward), orsREV (reverse) buttons
to adjust the time.
3. Press the H button again until the clock display
otherwise, the flashing stops after five seconds and
the current time displayed is automatically set.
to 24 hour, press the H button and then the
Once the times 12H and 24H are displayed, press the
select the default. Press the H button again to apply
With Date Display
Single CD (MP3) Player
time and date.
2. Press theHbutton and the HR, MIN, MM, DD,
YYYY (hour, minute, month, day, and year) displays.
selected, increases by one.
press the right SEEK arrow or\FWD button.
sREV button. You can also turn the f (tune)
The date does not automatically display. To see the
date press the H (clock) button while the radio is
on. The date with display times out after a few seconds
and goes back to the normal radio and time display.
Mar 15, 2010 | 2008 Chevrolet Impala
Display too dim to see
I purchased a new clock module off the internet to try.
Mar 22, 2009 | Jenn-Air JJW9530C Stainless Steel Electric...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Clock problem
had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
Jan 21, 2008 | De Dietrich DOC310 Electric Single Oven
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
Time
Here is the link to the user manual if you need it; http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070339_291093650,00.html You have to register to download it, but it is free. Also in the FAQs is this; "SETTING THE CLOCK How do I set the clock on my single CD player? For this Pioneer single CD player, you can set the clock using the following steps: Press and hold the SOURCE button till the radio shuts off. Press and hold the SOURCE button again, until display pops up, then release. Press the FUNCTION button until the clock shows on the display. Press the UP and DOWN buttons to adjust the hours. Press the LEFT or RIGHT arrows to move to the minutes. Press the UP and DOWN to adjust minutes. When complete, press the SOURCE button to exit." Hope this helps :)
Apr 05, 2007 | Pioneer Premier DEH-P580MP CD Player
Clock
Here is the link to the DEH-P3900 website page (sorry is the closest i could find, but changing the clock is the same); http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070337_337273636,00.html You can download the manual from there - you have to register, but it's free. if you want a quick way, pioneer says: "SETTING THE CLOCK How do I set the clock on my single CD player? For most Pioneer single CD players, you can set the clock using the following steps: Press and hold the SOURCE button until the unit turns off. Press SOURCE and hold again until the clock appears in the display. Press the left or right arrows to select the segment of the clock display you wish to set. (As you select the segments of the clock display the segment will blink.) Press the up or down arrows to either increase or decrease the numbers in the blinking segment. Once the clock is set correctly, press the SOURCE button to exit." Hope this helps - please post again if not :)
Apr 03, 2007 | Pioneer DEH-P3700MP CD Player
Samsung P520 Logo
101 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
