Question about LG Kitchen Series 30" Self-Cleaning Freestanding Gas Convection Range - Stainless-Steel
Lock feature my lock feature is on and i don't know how it got locked or how to unlock it.
  • jennys67 Feb 20, 2009
    Went to use and it says LOC ON. Stove top works, but not the oven Thanks
  • Anonymous May 12, 2009
    Same here. Tech support no help. Say it's out of warrantee and need to call a repair man.
LOC on is a lock out feature to prevent kids from playing with the stove. press 9 and 0 for 3 seconds and the loc will go off.
Posted on Jun 06, 2009
Where is the Ford 2010 Ford Explorer "Remote Keyless Entry (RKE) module" located
The RKE is controlled by the SJB - smart junction box ! Fords BCM - body control module .
Principles of Operation
Power Locks
The SJB controls the power lock/unlock feature of all of the vehicle doors, including the liftgate, to lock or unlock based on the input received from the door lock control switch, the keyless entry keypad or the remote keyless entry (RKE) transmitter. Power locking and unlocking of the doors function independently of the key position, vehicle speed or transmission position. The smart junction box (SJB) activates internal relays to supply the correct voltage and grounds for the door lock actuators.
Your best bet would be to take to ford dealer or some other qualified repair shop .
Remote Keyless Entry (RKE) Transmitter Lock/Unlock Control - Unlock
The RKE transmitter feature provides lock/unlock functions independently of key position, vehicle speed, or transmission position. The RKE transmitter feature provides a 2-step process for unlocking the doors. Upon receipt of the first request for unlocking the doors, the RKE control feature requests the SJB to unlock the driver door only. If another unlock request is received within 3 seconds of the first, the RKE transmitter feature requests the SJB to unlock all the doors. This feature can be changed to global unlock, so that all the doors unlock on the first press of the unlock button. To toggle between the 2-step unlock and the global unlock press the lock and the unlock button on the RKE transmitter at the same time and hold the buttons for 4 seconds. The turn signal lamps flash to confirm that the feature has been toggled.
Remote Keyless Entry (RKE) Transmitter Lock/Unlock Control - Lock
The RKE transmitter feature requests that all the doors be locked when the lock button is pressed. On any press of the lock button with all doors closed, the SJB provides 1 flash of the parking lamps. If any door is ajar, no flash occurs. As soon as the last door is closed, the SJB provides the flash of the parking lamps. If 2 presses of the lock button are received within 3 seconds, the horn chirps once, and the parking lamps flash twice to indicate that all the doors are closed and locked. If any door is ajar when the second lock request is received within 3 seconds of the first, the RKE transmitter feature requests the SJB chirp the horn twice without flashing the parking lamps to indicate it locked all the doors but 1 or more doors are ajar. When the key is in the ON or START position, the parking lamp flashes and horn chirp confirmations do not occur.
All locks not working ?????
  • The doors do not lock/unlock using the remote keyless entry (RKE) transmitter
  • RKE transmitter battery
  • RKE transmitter
  • RKE transmitter programming
  • Aftermarket system
  • SJB
  • Go To Pinpoint Test H .
Apr 16, 2017 | Ford Cars & Trucks
I have a 06 subaru impreza win i lock the windows the radio goes off please help
Hi Charlie.....when you lock your windows ? I didn`t know you could " lock the windows " -- my `04 doesn`t have that feature ... you don`t mean lock your doors...do ya ???
bummer..I was just at the dealer for an oil change and switch my winter over to summer tires....I would have asked then...
unfortunately Charlie...I have never had that problem ... sounds like something to do with the wiring ??? does the sound come back when you unlock them ?
other than that.... how do you like your Subaru ??? how many yrs you`ve been driving ?
Brenda
Jun 06, 2014 | 2005 Subaru Impreza
Baby locked my tv I didn't even know it had a lock feature
Consult the owner manual and if do not have it GOOGLE the model number of the set with "manual" to try to locate one for free.
Other option is call whoever the maker is and have the customer service rep step you thru the process to reset/unlock the feature.
Apr 05, 2012 | Televison & Video
I have a 1998 chevy suburban. The dome lights don't work. checked fuse box under hood. All good. Are there other fuses on the truck?
Instrument Panel Fuse Block
The instrument panel fuse block access door is
located on the driver side edge of the instrument panel.
Pull off the cover to access the fuse block.
The vehicle may not use all of the fuses shown.
Fuses Usage
1 Rear Seats
2 Rear Accessory Power Outlet
3 Steering Wheel Controls Back light
4 Driver Door Module
5 Dome Lamps, Driver Side Turn Signal
6 Driver Side Turn Signal, Stop lamp
7 Instrument Panel Back Lighting
8 Passenger Side Turn Signal, Stop lamp
9 Passenger Door Module, Driver Unlock
10 Power Door Lock 2 (Unlock Feature)
11 Power Door Lock 2 (Lock Feature)
12 Stop lamps, Centre High Mounted Stop lamp
13 Rear Climate Controls
14 Power Mirror
15 Body Control Module (BCM)
16 Accessory Power Outlets
17 Interior Lamps
18 Power Door Lock 1 (Unlock Feature)
19 Rear Seat Entertainment
20 Ultrasonic Rear Parking Assist, Power Liftgate
21 Power Door Lock 1 (Lock Feature)
22 Driver Information Centre (DIC)
23 Rear Wiper
24 Cooled Seats
25 Driver Seat Module, Remote Key less Entry System
26 Driver Power Door Lock (Unlock Feature)
Aug 23, 2011 | Chevrolet Suburban 2500 Cars & Trucks
Dryer is on LOCK CONTROL how do Iget it off?
The model number did not cross but here is what the manuals say for a Duet dryer:
CONTROL LOCKED
This feature allows you to lock your settings to
prevent unintended use of the dryer. You can
also use this feature to prevent unintended
cycle changes during dryer operation.
To enable the Control Locked feature:
Press and hold the End Of Cycle Signal button
for 3 seconds. The control is locked when a
single beep is heard and the Control Locked
status light is on.
• When the dryer is off, it is not necessary to
press the Control On button before activating
the Control Locked feature.
To unlock the Control Locked feature:
for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control
Locked is on, the dryer can be stopped by
pressing the Pause/Cancel button, but cannot
be restarted until the control is unlocked
Let me know if this does not work.
Kelly
Jan 22, 2011 | Whirlpool Washing Machines
Control locked
If you want to enable the Controls Lock/Unlock Feature:-
To enable the Controls Lock feature when dryer is running: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds. The control is locked when a single beep is heard and the Controls Lock status light is on. This feature allows you to lock your settings to avoid unintended use of the dryer. You can also use the Controls Lock feature to avoid unintended cycle or option changes during dryer operation.
■When the dryer is off, it is not necessary to press the Control On button before activating the Controls Lock feature.
For unlocking: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds to turn this feature off.
NOTE:- When the dryer is running and Controls Lock is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Good Luck and have a nice day
Rating the solution is highly appreciated.
Jun 29, 2010 | Whirlpool GEW9250 Electric Dryer
HAVE A WHIPOOL DRYER IT SAYS CONTOLS LOCKED DON'T KNOW HOW TO UNLOCK IT
Locked light is on, the dryer can be stopped by
Aug 03, 2009 | Washing Machines
I have a ge spacemaker xl800 microwave. my child has pressed some button(don;'t know which one but now all the buttons are saying 'locked' what do i do?
i'm assuming that you don't have the manual. The unlocking procedure should be in the manual. Models with a child lock-out safety feature should have a "Help" button that will lead to an un-lock procedure or a special button that you need to hold for 5 seconds. Try holding down the "0" button or "Start" button for 5 seconds.
Aug 10, 2008 | Microwave Ovens
Phone Locked
We may be able to help you if you could tell us the model of your Uniden DECT 6.0 phone.
Aug 02, 2008 | Uniden DECT 6.0 Cordless Telephone...
LG Kitchen Series 30" Self-Cleaning Freestanding Gas Convection Range - Stainless-Steel Logo
304 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
