Question about Philips GOGEAR SA6045 MP3 Player
Won't charge The player won't charge when it is pluged in only says ok to disconnect.
  • Anonymous Dec 26, 2008
    Mine says ok to disconnect also?
  • floyd4ford Dec 26, 2008
    I have the same problem mine says ok to disconnect when charging but it wont charge?
  • 8,596 Answers
Make sure the hold/lock switch is not engaged - see manual for details. Probably needs to be replaced - that is a sure sign of a hardware issue, and it is not something that can just be repaired. but, just to be safe, try this:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
My philips gogear 4g is pluged in and works but when i unplug it it says low battery and shuts off immediatly it has been left on for 4 hours now trying to fully charge it will not charge is the battery...
If the media player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 26, 2011 | Philips GoGear ViBE Digital Media Player
HI, i Have lenovo 0769-A63 laptop i have problem in my battery, when i put AC then my laptop is start,battery shows 83%(pluged in,Not charging). when i remove the AC System is cloosed is just like Cpu, its...
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 12, 2011 | Lenovo 3000 N200 Notebook
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
I believe the mp3 player's charge to last for 15 hours. It is only holding a charge for about 5 hours
Ifthe recharageable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 26, 2011 | SanDisk Sansa Clip MP3 Player
Battery dead unless pluged into computer. Charges
Friend, the power switch is damage thats why the charger acted as switch. replace the power switch
Jul 17, 2009 | Sony NWZ-E436F MP3 Player
704wifi charging problems
Return It.
Did the Other Charger actually work?
Oct 10, 2008 | Archos 704 WiFi Digital Media Player
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
Charging
you can't charge through the dvd player. you've got to disconnect the battery and charge the battery seperate from the dvd player.
Dec 06, 2007 | Curtis DVD8017 Portable DVD Player
Philips GOGEAR SA6045 MP3 Player Logo
93 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
