Question about Frigidaire FRS26RLECS Side by Side Refrigerator
Kenmore freezer/refridgerater 106#52699100
I have a kenmore freezer that is draining the water onto the floor of the freezer and then freezing it. Could it be the thermostat or the automatic defrost, or something else.
Thank You
Lympanyclan
2 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: water leaking onto floor when defrosting automatically
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
SEA BREEZE TIP's
Posted on Sep 04, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Figidaire model
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 08, 2010
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore refrigerator model 363-58572892 side by side refridge/freezer. Water is appearing on floor in fron of freezer side. Appears to be coming from ice maker. Crack in cce mold? Clogged drain? filling...
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 29, 2011 | Kenmore 64802 Top Freezer Refrigerator
Why does Ice build up at the bottom of the freezer side of my Kenmore side by side refrig model # 106.54602300? Purchased in 2003 Thanks Mark
Gene
Aug 13, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Model52552100 side by side kenmore. What cause ice build up on bottom of freezer?
Gene
Aug 10, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Elite 795.75542401 Water freezes on the bottom & then spills out to the floor. We can't find a drain hole anywhere!!
There is the drain in the freezer under the evaporator. You have to remove the rear panel in the freezer and the freezer floor to access it. Defrost it using a hair dryer and put hot water through the drain to make sure it's clean. Make sure the bottom end of the drain hose (behind the rear cover) is clean as well. Vacuum everything in the compressor compartment and keep it clean.
Please check the useful links bellow related to your query...
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itleaks
http://www.ehow.com/about_6736707_water-freeze-floor-bottom-freezer_.html
http://www.ehow.com/how_2208484_that-leaks-water-down-refrigerator.html
Let us know if you want something else please accept the solution.
Sep 20, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer drain not working. water accumulates and freezes in bottom of freezer compartment and sometimes will melt/leak onto floor
use hot water and turkey baster . force the water down the drain till it clear's to prevent it from freezing again install drain heater . some model's need them.
Jan 18, 2010 | Refrigerators
Water is accumulating in the bottom freezer and freezing...I continually have to chisel it out. We have tried defrosting it but have the same problem a few days later.
Hi.This will normally be caused by a clogged drainage hose or plug. There is a drain leading out of the freezer and another from the refrigerator. In top freezer models, the freezer may drain the water onto the back wall. It actually runs down the wall to the refrigerator floor drain. In other cases, there may be a drain tube leading out the freezer. The refrigerator drain is either located on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel. In side-by-side models, the freezer and refrigerator will probably each have an outlet to the drain pan under the appliance.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Dec 09, 2009 | Kenmore Refrigerators
Ice buildup on floor of side by side freezer floor..
Inside the freezer in the lower part of the back wall there's a drain hole wich probably is clough and the water from defrost doesn't go through and freezes up .Put hot water to defrost it and keep pooring it until goes through.If is still clogh try with a wire but do it ery carefull to not put a hole in the drain plstic tube.
Apr 22, 2009 | Kenmore 50522 / 50524 Side by Side...
Water freezing up in the bottom of the freezer
your defrost drain is stopped up then when it defrosts in steed og going down the drain its running in the freezer floor remove the back panel in the bottom of the freezer and clear the drain hole under the evaporator
Mar 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Frigidaire FRS26RLECS Side by Side Refrigerator Logo
74 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
