Question about ViewSonic N3251w 32 in. LCD HDTV
Screen Goes Black After About an Hour
I have had my tv for three years now and the tv works just fine up until an hour after use. The picture on the screen will go out, leaving absolutely no picture, however the power light will stay on and remains green. The sound will also go out and if I turn it on again, this problem occurs within minutes. However when I leave it off for a while, it works just fine when I turn it on again, but when an hour is up, I have the same problem again. Does anyone know what the problem might be and how I might be able to fix it?
  • cl0netr0oper Nov 08, 2008
    I have a bit of the same problem, except mine turns everything off. Not just the picture but the whole TV.
  • 4 Answers
Check the power board inside the TV, possible bad capacitors. I just had them replaced on mine.
Posted on Nov 21, 2008
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
New power supply board and screen goes black
It sounds that the off timer has been set to one hour. Check it.
May 29, 2013 | Philips 47PFL3704D 47 in. LCD TV
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Our lcd phillips tv screen turns completely white after about an hour of use
The TV, most probably, the display circuit or the display itself has developed dry solder/components leaking and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Philips Televison & Video
JVC LT47 that picture goes black (sound fine) after being on for awhile. Can turn TV off, then back on & it's fine. But then happens again about ever hour or so.
Hello
Hello
It is due to some loose soldering points [dry soldering we say it technically], in the power supply section of the TV. Just check for it. Check the solderings of all components, that will heat up to an extent when the TV works on. Repeated heating and cooling may make solderings to the terminals of that components to get loose. Just resolder all the suspected solder terminals, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. This must solve the problem to your tV. OK.
Feb 11, 2012 | JVC Televison & Video
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Jul 04, 2008 | Televison & Video
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
ViewSonic N3251w 32 in. LCD HDTV Logo
176 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
