Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Drive not showing up on my desktop
My Lacie hard drive is not showing up on my desktop. It was working on yesterday but today its not showing up @ all. Can you please help me out. thanks
  • 2 more comments
  • gbartler Sep 21, 2008
    Sam problem - yesteday disk didn't show up under Mac OS. I tried to connect it to PC/Win - same result. Disk was standing on the table all the time, no impacts/damages happened.
  • bruce287 Dec 07, 2008
    All suddenly my Lacie D2 quadra 500 mb does not show up on desktop,
    Itries another firewire port etc.....
    All my work is on it,  HELP
  • viens7 Dec 29, 2008
    It will just not mount on my desktop. I have changed cables, connections, and power supplies.
    This is the 3rd Lacie hard drive that has done this to me, Lacie never again! Way too unreliable for me and my company.
    I have not moved the drive at all.
  • elk912 Jan 03, 2009
    I had the same problem until I read your comments.  Luckily had an older Lacie 250.  Swapped power supplies and the Lacie 500 is working like a charm.  Thank you!
I'm not sure i can solve this problem--which started for me tonight as well with my lacie d2 quadra 500 gb--but i can share a possible explanation i've found online: apparently, they have lots of problems with their power supplies. see if the power adapter (the black brick) is making a hissing sound, or if there is a ticking sound coming from the drive itself. i have both these sounds. i am hoping all my data is safe and that my i.t dept. will be able to fix it with a new power supply on monday.
Posted on Dec 27, 2008
  • mongojones Dec 30, 2008
    well, my problem was indeed a faulty power supply. my i.t dept. tried a couple of lacie power bricks they had lying around, and then took one out of an unopened quadra d2 box, and it worked like a charm. hopefully, it won't repeat.
  • 3 Answers
My Quadra d2 500 shows a blue light and is making a rythmic clunk, not the normal whirr. It does not show up on my desktop - is all lost? I have many photos on it and thought that this was a good professional hard disk. Anyone with a solution?
Posted on May 05, 2009
Hi , you are right, I went to the Mac repair shop, they tested the powersupply, and it didn't supply enough power, it causes the harddisk to make a kind of klicking sound, because it is trying to start up. A new power supply is orderd. They didn't sell them seperate at this shop.
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Lacie desktop hard disk problem
The strange sounds you are hearing are the mechanical parts in the hard drive hitting the platters in the hard drive.
I would take it to a local repair center to see if they can recover any data. I wouldn’t mess with it too much as the hard drive runs the chances of a successful data recovery are decreased
About hard drive failure
http://en.wikipedia.org/wiki/Hard_disk_failure
I hope this info helps you in some way
Please rate
Thank you
Jon King
Aug 22, 2009 | LaCie (301015) 120 GB Hard Drive
My Lacie driver is no longer acessable
you could send me it lol :)
When you say it gives you a blank window did you leave it for a while - I have to do that with my 500gb hard drive which has a lot of stuff on it and it takes a while to read what it needs to before it shows the files / folders
maybe a defrag if you can get it back up and running and also try it on a different usb port on the back of the same computer it was working on
May 16, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
How to correct connection problem for two LaCie Desktop Hard Driv
Here is the support website for the LACIE products.  As far as I knowthis site simply answers questions. Sounds like the hard drives are bad to me.
http://www.lacie.com/support/
Jan 07, 2009 | LaCie Computers & Internet
LaCie HD won't show up on Mac desktop, quit showing up yesterday
Hello! Had the same problem - go onto the Lacie official website. Select whatever type of drive that it is you have, and simply go onto the software update page. I literally downloaded the desktop manager (I own the Sam Hecht Little Disk) and it appeared! Good luck
Nov 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Drive no longer shows up on desktop
Try a different USB lead? mine did something simialr because it wasnt getting enough power through the USB port - turns out the wire was duff. New wire sorted it - well cheap from ebay (about 2 quid)
Sep 15, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Not showing up on my desktop
I had this same problem. I you are experiencing this problem and you have a Mac. Go to the LaCie web site there is a firmware update for this drive. Download the firmware update application from the LaCie website, start it and follow the directions. It should fix the problem.
Jan 27, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie drive does not come on
Maybe the usb chip in the hard drive enclosure that converts ide into usb failed. You could replace the enclosure (they sell enclosures at best buy) but it could be quite a hassle.
Jan 04, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Jun 07, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
852 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
