I just tried to load my PS2 w/a disc and you can hear it wanting to spin but its not. so when i opened it up a little square metal clip fell out. how do i fix it?
So far I cannot find the little metal piece that is mentioned here, any idea where exactly it is? So far I cannot find the little metal piece that is mentioned here, any idea where exactly it is?
You can't post conmments that contain an email address.
I had a similar problem but mine didn't fall out luckily...
You'll find a space for the metal clip (please say you kept it) at the back left of the console (you may need a torch to see as it is quite small. The metal acts as a connector to tell the ps2 when the lid is shut and to commence disk reading, otherwise as you experienced, disks won't spin
Well has it been dropped? If so more then likely the guide rail fall out of place and can easily be poped back in place. A good way to see if its your laser or guide rail is to fined the hole that when the lids closed this pin goes in the hole so the ps2 knows the lids closed and stick a piece of paper in that hole with lid opened. Now it should act like the lids closed. See if the laser produces a red beam or strange noises. Maybe even the little black piece at the back that stops the disc from spinning isnt working right. But dont get worried as theres a pin on the lid that makes the black piece pull back from the disc when lids closed so it might be stopping disc from spinng while its open. Several diffrent solutions need to know how you know its not spinning. If your just putting your head to it and cant hear it spinning then you will need to trouble shoot.
Can you hear the fan spinning on the inside of the PS2? If the PS2 comes on, loads the disc, then shuts itself off, chances are it is overheating and shuts off to prevent damage. There is a small fan on the inside of the Slim PS2 that keeps it cool.
If you press the reset switch and it goes from red to green and immediately back to red without ever turning on, your motherboard is shot. ESD damage.
I just looked at a friend's PS2. Same story, tripped over cord, unit fell to floor. Unit powers up and sys. config. screen comes on but the drive didn't seem to be spinning up. Opened the case and found that the shaft of the drive motor for the laser tray had popped out of it's centering retainer ( little black bushing/holder). With the top off the unit, looking at the unit from the front, on the right side in the rear corner you'll see the motor. The worm shaft (bronze colored rod) runs towards the front of the unit. Where it ends it should sit centered in a black plastic holder, if it's off to the side a little pressure will pop it back in. Put the cover back on, and power it up, you should hear the drive spinning up. If it does you should be set. Hope this helps.
try both audio and game disks if it will not turn the disks then the motor hub on the ps2 is shot if it will play the audio cd and not play the game then the laser is out of alignment but if you hear it spinning it could also be a burnt out laser as well further information would be required to diagnose this issue further.
mine did the same thing if u open it up it probably looks like it should but if you look closely at the gear the drives the lenses up and down it might be out of line simply pop it back into place it will take a little force to pop it back in
I believe your PS2 is extremely dirty and full of dust and lint. It needs to be opened up and cleaned out throughly.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
Disconnect power and turn the case upside down.
Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
Remove all the screws.
Remove the Warranty sticker to the right edge of the power socket.
Turn the PS2 over to set it right side up.
lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
Remove the CD tray lid.
Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
Hook up the power and A/v Cables.
Remove the little white disc from the CD tray lid.
Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
Boot up the PS2 and test it, Continue cleaning until you get it to work.
Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Have you try-d cleaning the lens with a cheep cleaner ((disk type)) some times a can of compressed air works to blow the junk out.OPENING IT YOUR SELF LAST RESORT . but if you have to ill make ya video on how to replace it.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact [email protected]
