Here is the link to that owners manual
https://www.maytag.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%202206682.pdf
click on it to download it,and if ya wish you could print it as well.
GENE
SOURCE: no heat
Check for the wire inside the unit, maybe it's broken or cut off, replace or join it again will solve the problem
SOURCE: Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Testimonial: "Good advice fast. Thanks very much."
SOURCE: I need to install a
Hello, tyviper I was trying to helpyou out here. I am not sure if this well help you, but here is a link to abouteverything you want to know about your dryer, from repair to trouble shootingit. If you go to this link and click around, I am sure you will find out so muchabout your dryer, you will know more that the company that made it. Here Is thelink for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helpedyou at all, if you can find the time to rate my help and some kind wordswritten would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
