Question about Samsung SCH-a930 Cellular Phone
Power cycling My phone won't stop powering on and off. It turns on, acts like it is loading and then restarts the whole thing over again. The only way I can get it to stop is to take out the battery. Is there anything I can do? I took it to Verizon to see if they could check the battery and they just said I need a new phone. I like this phone and all my contact info will be lost. Please help.
  • 4 more comments
  • Michael Tibbetts Oct 04, 2008
    Mine is doing the same thing and I just posted. It started doing this when I attempted to forward a video message. My video memory was full prior to receiving this message and I suspect the lack of space may be contributing to the problem.
  • brandonwilso Nov 09, 2008
    i have this same problem is there any way to fix it
  • legacy_lee Dec 12, 2008
    My phone is now doing the same thing. The ironic thing is that I was actually about to write down all my contacts just incase something happened to my phone. Well, too late now... or is it? Anyone else find a solution to this problem. I tried the method above but to no avail. Even with the battery out of it, as soon as I connect it to the charger the power cycling starts up again and continues to do so even when I throw the battery back in. I too can not lose all my contact info or is that even a possibility now?
  • barclay1993 Feb 16, 2009
    i tried the solution but i still have the same problem
  • Emeraldes Feb 19, 2009
    I am having the same problem. Is there anyway to get my personal data off it??
    I am having the same problem. Help....please!!
I had the same problem. Actually, it began about thirty minutes prior to me posting this solution. Of course this may not work for you but it worked for me.
My problem began after I plugged my phone into my computer. I hadn't done anything to it. I went to turn it on and it entered the seemingly endless restart cycle. It likely had something to do with being plugged into my computer. I toyed with the battery and whatnot but to no avail. Eventually, I took the battery out and put the phone on AC power instead. It made the cycle shorter for some reason but did not solve it.
I then put the battery back and put the phone on AC power. I powered on the phone and it went to the initial loading screen. After that, it went to the charging screen which was weird because my phone should have been at 100%. From there, it proceeded to power on competely. End of problem.
I will note that I also had my USB sync cable plugged into my phone although it was not plugged into the computer. The charger was plugged into the adapter port on the sync cable but I suspect you'll get the same result without it.
Posted on Nov 18, 2008
My 6 year old Whirlpool Sport Duet washer will rarely stay running for a whole cycle. The power switches on and off on its own...it adds extra rinse cycles and won't allow you to turn them off, it...
Hello & Welcome to FixYa
I Agree, I don't think it is any other board, I believe the CCU (central control unit) has gone bad as it keeps on stopping mid cycle. If it was the Motor Control Board (MCU) then the washer motor should have been causing problems (which isn't the case) so replacement of CCU will be a great option. Please get back to me if you have any other questions.
Kevin
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When i apply power, the cpu fan and power supply fan turn a few times then they stop and restart. This cycle continues for about ten minutes then the OS loads and runs fine. This happens every time I turn...
That means the PSU( power supply unit ) is already malfunctioning. Try to use a spare PSU and try that if that happens again.
Hope that helps you out!
Aug 09, 2011 | Intel DH55TC Motherboard
Washer won't turn on at times. It acts like it has no power. Unplugging electric cord from wall socket and reconnecting seems to reset the unit and it functions normally for a while. After an hour or...
Try this first, unplug the unit and connect it to a different outlet and see if it corrects the problem. If it still continues, you will need to replace the control board. Good luck.
Jun 18, 2011 | LG WM2301HW Front Load Washer
My Kenmore 110-46462501 washing machine stopped mid-cycle
Can you hear the pump running? It might be plugged or not running
Oct 20, 2017 | Kenmore HE2 Plus Front Load Washer
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
My Pantech c150 just keeps restarting
Try performing a hard-reset. Take the battery out of the phone for at least a minute and hold down the power button for at least ten seconds afterwards. Replace the battery and turn the phone on, and it will have hopefully cleared up the problem.
Jun 02, 2009 | Pantech Matrix Cell Phone
Whirlpool washer sometimes stops after the wash cycle
Sounds like the timer has given up. I bet if you just barely turn it, it will continue.
It's a common problem with timers like this.
Replace it.
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
Fisher/Paykel Smart-drive 5.5 auto washing machine was on final spin cycle and starte making unbalanced load noises. I stopped it,redistributed load and tried to restart. It restarted in spasms so I took...
sound like the controller opr micro board is sick. unplug leave off for a few minutes then power up again and try empty wash cycle if its the same call the engineers.
Apr 22, 2008 | Washing Machines
Samsung SCH-a930 Cellular Phone Logo
176 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
