Question about Philips 43P8341 43" Rear Projection Television
Red convergance I have a Philips 43P8341, made in 2001. The picture as a bow at the top and bottom of screen. There is no convergance control. The red is off about an inch and I am not able to converge.
  • jcol8871 Sep 30, 2008
    I also have a red convergance problem with a bow in the bottom left hand corner. Would like to know if there is simple fix to the problem.
  • rodrick346 Sep 30, 2008
    I have Philips 43pp6360 43in Rear Projection TV with Red convergance problem.
    I am not sure if the fix posted for 43P8341 TV can be the same for my one.
    I need someone to advice me on this.
  • Philips Master
  • 8,617 Answers
You will need to replace both convergence ICs they are STK392-110 and you will also need four 6.8 ohm 1watt resistor. You can get replacement ICs and resistors at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Posted on Sep 21, 2008
Bowed picture on Philips 55pp9352 after replacing IC's
You must have mishandled the ICs they are static sensitive, and unless you used Sanyo ICs then you will have problems. The convergence is obviously not working so the TV will need the digital convergence board repaired or replaced, also the PIP board is suspect I have seen plenty of these tvs and believe me I earned the $ 350 we charged. These sets are very difficult to work on even for a trained tech. the best thing to do is to have a repair shop do it and you will have the assurance that its done correctly, and the work is guaranteed, That makes sense. ( I will not be able to respond to any further inquires)
Jan 04, 2010 | Philips 55PP9352 55" Projection Television
Philips 43P8341 picture bowed red wont line up
You will need two STK392-120 convergence IC and about six 6.8 ohm 1watt convergence resistors you can get the parts at the following link and they provide free step by step instructions with pics.
May 27, 2009 | Philips 43P8341 43" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Cheap Fix?
I will strongly advise you to replace the two STK392-120 as a pair. and this will cure your bowing picture problem. You may need to re-converge your set. best of luck.
Nov 05, 2008 | JVC AV-48WP30 48" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
50P8341 red bows
Convergence ICs or the resistors powering them are bad. Check for open resistors near the ICs if any are open, change both ICs and the resistors.
Feb 10, 2008 | Philips 50P8341 50" Rear Projection...
Picture Quality
Sounds like your convergence amps are probably bad. Check out http://i114.photobucket.com/albums/n248/OFilippov/Dont%20look/Pioneer/BadPicture03.jpg and see if you have similar bowing between red and green when you try multipoint convergence. If so, you'll need new convergence amps, part STK392-120. Most people who are handy with a soldering iron can replace these parts in a couple hours.
Jan 15, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9363H/17
Screen looks 3D
Solution:
Jan 11, 2008 | Philips 60PP9363 60" Rear Projection...
Blue out of whack around sides
I have the convergence problem with the red. After reading your site I replaced the 2 ICs and the problem is worse. Before the only problem was I could not adjust the red horizontal. Now I have no control over the vertical or horizontal and the overall picture is very red and it bows at the top and bottom very bad. A friend said I might have the ribbon connector in wrong or the convergence (silver box?) box maybe bad. Any ideas? Thanks,Dave.
Oct 12, 2007 | Philips 55PP9352 55" Projection Television
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 43P8341 43" Rear Projection Television Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
