Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Reconnecting the modem
My 3yr old modem works only intermittently so I bought a new gt704wg. Instinct tells me to just plug and play. The new one from Best Buy did not come with an installation CD nor many explicit instructions. I am kind of afraid to go ahead and start the process because I don't want to be left with nothing. Does anyone have any suggestions. I don't have the installation CD from 3 years ago.
They do not have any install CD. You have to set it up and then call Verizon to help you set it up completley but you swill be able to get to the 192.168.1.1. site so you can get it online
Posted on Nov 11, 2008
I see that people are asking about driverss for the RCA dcm425 cable modem. I just bought a new computer, and I connected it to the my old dcm425 modem through a router and it works just fine. I didn't...
The trick about all this is that the software does not configure the computer, but the modem.
So once it has been configured through a computer then plugged to a router, any computer plugged to the said router will have access to the Internet.
The whole process of installing/configuring will happen if you replace the old modem and/or plug a new computer directly to the modem.
May 07, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Hi I want to know on how to setup the verizon Modem/Router I already have a Westell 6100G and i want to upgrade to the new one called Verizon Wireless modem/router model:GT704WG.
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported.
Aug 28, 2010 | Actiontec GT704WG Wireless Router...
When power switch is turned on the Power light is rapidly flashing & the 4 Ethernet lights are flashing. The box is Actiontec GT704wg
I do not have a solution to the problem. However, I am having the same problem. This morning the Actiontec GT704WG power and ethernet lights were rapidly flashing. The modem was non-functional. I could not even connect to the modem through the browser to see if I could find a problem.
The problem lasted a couple of hours. Then all of a sudden the modem started working again. I won't be able to tell if the problem recurs until I restart the modem. And if the problem does occur again, I won't be able to connect to the internet.
Oct 08, 2009 | Actiontec GT704WG Wireless Router...
Very intermittant skip 03 bravada
you might want to scope the ignition module.
Sep 16, 2009 | 2006 Chevrolet Trailblazer
Can you connect your internet from the samsung instinct phone to the ps3?
If you have a phone as modem plan sure you can, If you have the Instinct I am asuming that you are w/ Sprint. If so and you have unlimited data plan go buy a 3G to broadband wireless router. I suggest the Cradlepoint 350 or better, Best Buy sells them for about $100. It will convert your 3G signal and then your PS3 will be able to see the network, set it up with either no passcode or use the WPA/TKIP for encryption. It works fine, I have the HTC Touch Pro and it works perfectly, its easier if you have a Windows based phone though.
Jul 24, 2009 | Samsung Instinct Cell Phone
I bought a GT704WG wireless modem from Verizon, but it doesn't appear to have any drivers installed. Where can I download them for no charge?
Try this link:
http://driverscollection.com/?H=GT704WG&By=Actiontec
It has usb drivers, firmware update, and an ISO CD image of the device's manual.
Jan 31, 2009 | Actiontec GT704WG Wireless Router...
Constant intermittent loss of connectivity, even with new gt704wg router
It might be that you have a voltage drop. I noticed that this modem is very sensitive to voltage 'dips' and it will 'reset' itself if even the slightest dip in power hits it.
I have a A/C that sucks power when it cycles and every time it does I lose the internet connection. So I set up a 12 volt battery with an DC to AC inverter and run the modem off of battery power.
That might be the problem your having.
Aug 26, 2008 | Actiontec GT704WG Wireless Router...
My Lacie 500GB drive shuts my laptop down when i connect it.
similar issue: my notebook hangs instead of restarting. i thought its the usb2.0 of my rather old(3yr) notebook. but i bought a cheap usb box for my old 120G hdd and it plug-n-play like a charm on the same old notebook/same usb port. quite frustrated with this Lacie 500G beast.
so i ended up backing up my notebook using the 1-click backup of Lacie but using my old 120G hdd instead of the new Lacie500G. but then, search as i would through the Lacie documentation, i see no mention of how to restore the data... still looking...
Jan 27, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Cannot connect to admin on GT704WG
try power off/on and then reset hold the reset in for at least 10sec - holding it in for 1-2sec is the same as power off - but i would still physically remove the power for at least 30secs remove all the lan cables - just plug in the one PC you use then hold the reset for 10secs 192.168.0.1 - is the default login - so should work now - if not the router is faulty whats the status of all the lights on the router
Apr 13, 2007 | Actiontec GT704WG Wireless Router...
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Richard Schabler
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
