Question about Samsung Televison & Video
Samsung HL50A650c1f dlp tv
My tv when i plug it in goes on and off repeadetly
  • Jeffery Mitchell May 22, 2012
    I have the same exact problem. I tested all electrolytic caps in the power supply and all were good. I changed out the ballast and still had the problem. I need the schematic that shows the power supply for this model. I don't see anywhere to send a private message to Gopakumar Gopalan who has it. How can I contact Gopakumar Gopalan to give him my email address?
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: odd sound from Samsung DLP TV
Buzzing could be related to the lamp/ballast connection. Try removing and reinserting the lamp look for arching marks on the contacts that would suggest that the connection wasnt good.
Posted on Mar 29, 2008
gopakumarg43
  • 74887 Answers
SOURCE: Samsung 50" DLP tv goes on, freezes, goes black,
Hello
Unplug your TV from Ac mains socket and wit for some time, say 15 minutes or so. unscrew the lamp case, take it out, and reset it as it was, and tighten the screws. If lamp is not well tightened this type of fault will occur in DLP TVs. Also, if lamp life has out too. Check this first. If the problem perists after doing these, the internal circutary, especially to the power regulator side has some trouble with it and should be checked well. If you have a sound knoledge in digital electroncis, and the working of DLP tv [as DLP chip is very costly] only attempt to do it by yoursef at home. If not don't go further. Anyway inform me after doing these first. OK.
Posted on Apr 16, 2011
Samsung BP96-01653A Model HL50A650C1F I believe that the lamp went out on my Samsung 50 in DLP TV about a week ago. The TV would not turn on and the green lamp light blinks. I ordered a new lamp, fr
This sounds like a case where jumping to a incorrect conclusion has not resulted in the fix your were after. The problem could also be related to the power supply. Before going for another part it is best to consult a Technician who works on these all the time and get a correct direction to go before ordering a lot more parts. if you check on the internet with the symptom and model /brand of your unit- chances are someone else has already had this problem and may have the solution there for you to take advantage of. Of course each TV is different but it might be a better way to proceed than just guessing.
Aug 09, 2012 | Samsung HL50A650 50 in. TV
Samsung DLP TV HLN617W1 picture comes on then goes out after several seconds and all 3 lights flash
Ha the Lamp ever been replaced and if so how long ago? If you have never replaced the lamp then it is time to replace it 1-800-628-1118
Oct 15, 2011 | Samsung DLP HL-P5663W 56" TV
I have a samsung dlp when i plug it in i see the fan go on and also here a hum is that the fan or color wheel? andy way the lamp goes on and no picture. the lamp light is on in front. how do i know if it...
Check this link it may help - also if your lamp is trying to light you should see some light and hear a sparking noise from the board (ballast board with spark gap lighting)the lamp is plugged into (internally).
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 06, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
White spots on Samsung DLP
Hello the problem here is absolutely the DMD Board this is a commune problem with the Samsung DLP
are your spots like this picture?
try this link...
http://www.discount-merchant.com/
Jun 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Screen goes blank after being on for a while
if it goes black but the light is still working the dlp chip is failing this is like a small lcd screen that the light use for the piture to work looks like this http://www.fixyourdlp.com/2012/04/24/the-affordable-solution-to-white-dot-syndrome-on-your-dlp-tv/ hope this help you.
Jan 30, 2018 | Samsung DLP HL-P5663W 56" TV
White dots, multiplying daily.
This more or less means you have a bad hdmi plug, unlug it from your cable box and watch what it does if your tv automatically goes to the waiting screen and the white dots re apear its The hdmi plug, so the hdmi plug needs to be replaced...they arent cheap maybe 40-75.oo depending on how nice of pic you want
Mar 25, 2009 | Samsung DLP HL-P5663W 56" TV
TV Picture problems
My samsung did the same thing right before my color wheel went out. Can't be sure but that is what was wrong with mine. hope this helps.
Jan 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
MY Samsung DLP TV Has Green/Purple Lines
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 08, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
503 people viewed this question
Henry  Thomas
Henry Thomas
