Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
Colors are negative, I have the intial data valus but don't know what the original settings for the o and u are.
  • donna_flick Oct 14, 2008
    and yes, this is the case, so how do I reset original values?
  • lngroller Jan 27, 2009
    I have a similar problem, seemingly inverted colors but menu colors fine. I have done a lot of electronics repair. no the dangers of the HV and have no problems with soldering iron. If it makes any difference my set is a 14 year old Mitsubishi CK35304
    New Friend:
I have the same issue. Menus are inverted too.
Posted on Jan 06, 2016
    Scholar:
  • 186 Answers
If all colors seem inverted - quite possibly a power supply over feeding or underfeeding the unit..... Check to see if menu seems inverted too.
Posted on Oct 12, 2008
How do I restore colors to IPad 2 screen assessibility does no work?
so u made everything negative and trying to make it original colors again??
Nov 14, 2014 | Apple iPad 2 Wifi 16GB
Speakers don't work quite right
Check first to make sure impedance marked on speakers is same as original---two sets of positive and negative terminals suggests original ones were dual element speakers----
If for example original were marked 8 ohm and you put 16 or 32 ohm speakers in----volume will be greatly diminished and even distorted.
This is only a suggestion as I do not know what original speakers were or what new ones are----but the key is originals had two sets each of connections.
May 18, 2012 | 2002 Oldsmobile Alero
Radio wiring diagram- 2007 Silverado
Ok this is for the factory wiring,The wire colors are for the right rear speaker are,dark blue is positive,light blue is negative.Right front door is light green is positive and dark green is negative.Left front,tan is negative and gray is positive.Left rear is brown positive and yellow negative.Hope this helps.Good luck.
Feb 17, 2012 | Chevrolet Silverado 2500HD Cars & Trucks
Cannot remove password
You can only disable the password if you already know it. If you don't then there is no bypass, not even RIM can do that. BlackBerries are designed to be secure which is exactly why governments and corporations like them.
If you make too many attempts to guess the password you'll eventually be prompted to enter the word BLACKBERRY. This will then totally and irretrievably wipe the phone of all data and return it to its original factory settings. The phone can then be used as normal. Note that if the phone has the Enterprise edition operating system then the phone can be set to be totally unusable.
If the phone data has been backed up to a host pc then the original data can be fully restored, but only if you remember the original password.
Sep 24, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
Color prints look like a photo negative, can't get to print colors correctly
This should be under 'printers' not 'motherboards', however, it seems you have set your printer (unknown model) to this Negative setting. It could be a setting on the printer itself, or a setting in the software of the printer but without knowing what model, this cannot be determined.
Oct 13, 2010 | Computers & Internet
Reset the date and time to original factory settings
Please follow the steps below to reset the setting to default...
1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sx200resetscreen.jpg 3. Using the arrowdownbutton.gif button, select [Reset All..] and press funcseticon.gif. sx200menudirection.jpg 4. Select [OK] and press funcseticon.gif. sx200resetconfirm.jpg
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language] and [Video System] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • Newly added My Camera settings
Feb 19, 2010 | Canon PowerShot SX 200 IS Digital Camera
NEED STEREO WIRE COLORS FOR 1988 BMW 735I
red = constant live 12v
brown = negative ground
violet = ignition live 12v
white = electric antenna (rear screen)
the speakers will be twisted pairs, i can not remember which is left and right but the grey stipe and brown strip are negative the others are positive.
If in doubt get a pro to install for you as you could cause damage if you connect wrongly.
Nov 25, 2009 | Car Audio & Video
Dim backround and display on westinghouse LTV-40w1 HDC tv
u will have to go into service menu to set sub brightness be carefull u may do more bad than good write down all valus before atempting to adj.
Dec 08, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
I need the color codes for rear speakers in a 1996 thunderbird lx.
positive wire is red, yellow wire is positive on ignition okey for the speakers remember the solid color like green green w/ black line is negative follow the other coding w the solid colors
Apr 12, 2008 | Pioneer DEH-P6800MP CD Player
IBM T30 laptop- replacing CMOS battery
Provided the laptop booted (albeit to requiring bios set up), all is well. The data such as time needs to be re-entered manually, because since the battery is required to maintain volatile memory, when the battery goes flat or is removed, the data is lost. Re-enter all data, including boot sequence (i.e. IDE 0, CD-ROM/DVD)! exit saving to CMOS. should reboot to OS.
Jan 28, 2008 | IBM ThinkPad T30 2366 Notebook
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
320 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
