Question about Nokia 1100
Network reception fading away when establish call
    Brigadier General:
  • 7,752 Answers
Have the curcuit board tested
Posted on Sep 21, 2008
I just bought a laptop and I wanna connect to wifi how can I do it?
First you must understand that wi-fi only works within a certain distance from the wireless router. It's not like cellphone reception where the wireless provider installs cells throughout the countryside to make sure that you can get reception. You have to either get your own internet connection to your house and your own wireless router, and then you have to install the wireless router, or you have to go to a coffee shop or other establishment (public library?) that provides its patrons free wireless internet while they are on the premises. Once you do one of those two things, then (in Windows 7) you have to click on the network connection icon in the lower left-hand corner of the screen, then click on the name of the wireless network that you want to connect to and click "connect", and then if prompted, type in the network key for that network. After this, you should be connected to the internet wirelessly as long as you are within range of that wireless router.
Mar 01, 2012 | Dell Computers & Internet
Whats the code in the menu to turn on HD channels?
First the televsion programming is made available from the establsihed structure. For example, time warner cable estblsihment makes the resources available once established. Second, dish network would make programming telecast channel signals available once establsihed also. Ascertain the televsion program establsihment to enquire details that makes channel display achievble. For example, registing details from time warner cable would evaluate to establish structures from where reception is attainable. Either as code prorgams or remote control preprgammed that least requires the use from establsihing setups. Conact a television programming establsihment to evaluate the devices at the location to provide a requestion professional establsiment to attain user experineces.
Feb 19, 2011 | Motorola Computers & Internet
My wireless USB adapter is not getting connected to the network, what do I do
prior computers have builtin network adapters that functioned as cable connection either dial up phone lin or ethernet cable connections. Computer of the recent generation have wireless adaptors that derive connective within radius of modems also known as wifi. Observe the computers made models as reference to ascertain whether requires cable connection to network or capable of wireless reception. Computers that are provided network structures by an expert would recognise either as requiring cable or wireless. Depending on the coniditon of computer structures requesting to establish a network structure is acheivable. Refer with a computer networkin technician that would evaluate the devices at the location to ascertain the requisite structures to establish networking telecommunications. For example, refering with an expert ascertains that the computer requires modems to capture the signals or modern devices require a miniature adaptor device attacked to the computer.
Feb 19, 2011 | Linksys Computers & Internet
Sometimes pictures are too brigth or too dark also it just suddely fades away. it has to be dark in order to watch tv. i just cannot get right colors or a clear picture,
may be the channel reception is bad.try adjusting the colour,brightness and contrast levels if problem is not solved contact the customer care
Feb 13, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
Using a Acer Aspire Revo. Running with linux Unbuntu 10.4lts. I have a BTHomeHub trying to connect my NWD-270N Wireless N-lite USB Adapter however it picked up the Hub and established a connection...
Select from the computers default internet networks, Recent computers are wireless enabled as the prefered networking. Attempting to introduce another network would share the connection capacity to any availabe signals. decide on the network type required. Pick wireless and disable the remaining networks to achieve an express signal reception and transmition.
Jan 29, 2011 | Zyxel NWD270N Wireless N USB Adapter...
My AM radio reception does not work. I have a loop antenna. The sound comes in for about 30 seconds, then fades away. Re-orienting the antenna does not work. FM reception is fine.
You should buy an antenna amplifier. Here are some that work in-line and are designed specifically for AM radio:
http://www.google.com/products?q=AM+antenna+amplifier&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&ei=sVRBTKGhD47msQOvpNCYDQ&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CDEQrQQwAA
Jul 15, 2010 | Yamaha RX-395 Receiver
I have a Cobra CB RAdio What model I don not know? It's similar to the cobra 29 Ltd. It has at least 6 knobs/dials. Anyway...I can broadcast out very clearly. However, when I go around a corner or...
id check the coax conector first then the wire and antenna if its not the conector or the coax try a differnt antenna if you still have problems its internal with the radio
Apr 04, 2010 | Cobra Radio Communications
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
Psp internet connection
common is there anything you can do to fix it
Jul 28, 2008 | Sony PlayStation Portable (PSP) Console
Nokia 1100 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
