Question about Gem Sound GemSound PA-585 2-Channel Amplifier
Gem Sound clipping problem
I have a dj setup with Gem Sound amp EXA-3950 (3000 watts-1400 watts max peak per) with 2 Gem Sound TR-300's ( dual 15" woofers- one horn and 5 tweeters on each speaker --1000 watts peak?). we seem to have clipping problems quite frequently as we near 50% amp capacity--particularly in large gyms for school dances. the mixer we use is a Behringer 2 channel mixer with the gain about half way up. any assistance would be greatly appreciated. thanks!
  • 4,234 Answers
First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
Dan
Posted on Sep 24, 2008
How do i hook up and ipod and/or computer to the Gem Sound CMP500
you need to connect the player to a dj 2 channel mixer using a red and a white RCA CABLE ...(line 1) then into (line 2) ... from pc /laptop ... need a stereo mini jack to 2 RCA (RED / WHITE) INTO back of the mixer ... before turning on please remember to set volume on pc/laptop 80% MAX ... and DISABLE EQ's or FX ... dj mixer has all the EQ / FX needed :
Mar 05, 2013 | Gem Sound CMP500 Dual CD / Mp3 / USB...
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
Son puissance max
800 watts per channel @ 4 ohm
400 watts per channel @ 8 ohm
400 watts per channel RMS @ 4 ohm
200 watts per channel RMS @ 8 ohm
Dec 13, 2010 | Gem Sound GemSound PA-2505 Car Audio...
What wattage amp do I need to get good sound in a toyota corolla
Make sure it's a RMS 1200 wats not MAX watts also the Ohms of this speakers and them you can buy any amp. with the same RMS watts of your speaker and same Ohms of resistance.
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
You guys was helpful last time so I thought I would ask more!!!! DJ equipment Gem Sound amp EVA-3955 at 8ohms 2x250w blew 2 Tr-150 15'' 8ohms rated at 600w blew. what replacement should I go with same size...
Typically large speakers like that blow up because you are trying to put frequencies into them that they can not reproduce. How are these units connected? Is the crossover frequency correct for these 15" speakers? Putting signals higher than about 1000Hz will start to heat them up. too much heat = blow-up.
Also, I'm not familiar with the tr-150s. Is the 600W rating a PEAK rating or continuous?
Dan
Jan 06, 2010 | Audio Players & Recorders
I have Exa 3955 amp and TR-150 subs mid range and tweeter works subwoofers stop playing both
Open the sub box, and check to make sure the sub wires didn't become disconnected. You should need only a screwdriver.
Jan 05, 2010 | Gem Sound Car Audio & Video
Gem sound exa 3950 amp
Hi...
If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
website
http://www.gemsound.com/contact.html#
Mar 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
Gem Sound GemSound PA-585 2-Channel Amplifier Logo
397 people viewed this question
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
Ernest
Ernest
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
