Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
Kawasaki Ninja 4-Wheel
A loud audible clicking or slipping of gears sound coming from back of the power wheel, if clicking continues for 5 or more times, vehicle does not go forward. Clicking seems to cease when operated in reverse. Any suggestions as to problem? If can be fixed, where to find parts?
  • BobandAidan Sep 28, 2008
    Thank you so much...information/instructions are very clear. Can you add any information about replacing and lubricating the gear(s)? How many gears or drive clutch(es)? Can I replace only the gears or do I have to replace the motor/gear assemblies?
    Thanks again...my grandson is patiently waiting me to fix his power wheels.
  • Anonymous Feb 14, 2009
    I got the new 2009 barbie kfx 4 wheeler and I beieve the back wheel is slipping. need to find it on line and order the gearbox and or motor for one wheel. anyone know where to find this
  • 33 Answers
I have taken a lot of these power wheels apart, there are nylon gears that when the vehicle is powered forward and cannot move the teeth on the plastic gears will wear down and slip.
Here is an ebay site.
To replace the gearbox you will need to take off the axle cap and shaft washer that holds the wheel on.
Slide off the wheel.
I think this power wheel has a silver plastic housing that covers the gearboxes and axle, which means that there will be an amount of screws to take out before you can get to the guts.
Once you get to the wires on the motor you will need to cut and strip them and install the replacement
If you can, I would prefer you would crimp the wires together with a blue or Yellow **** splice, but if you do not have crimper or lugs You can use wire nuts large enough to firmly connect both wires. Then electrical tape the nuts and wires to prevent loosening by vibration. Even though these are 6 volt batteries their current is enough for wires not connected well to overheat, melt and could possibly become a fire hazard.
Ideally the wires from the replacement would be the same color as the original but if not you will want to test to see if while in forward it does go forward. If not you need to reverse the two wires. This is a headache saving measure.
Re-assemble everything making sure that the axle nut or cap goes back on Tightly to prevent the wheel from falling off during use.
Posted on Sep 27, 2008
  • Unspecified Sep 28, 2008
    Replacing the gearbox and motor is a lot less messy and probably easier.
I have a problem shifting in to second gear on my 2005 zxr6 636
Hi, Robert and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2nd gear problem help
http://zx6r.com/zx6r/13501-2nd-gear-prevention.html
Kawasaki Ninja ZX 6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja ZX 6R Owner Manual
May 01, 2016 | 2007 kawasaki Ninja ZX6R
1999 Kawasaki ZX-9R Ninja clutch slipping
Hi, Anonymous and the usual suspects are:
1. Clutch controls improperly adjusted.
2. Insufficient clutch spring tension.
3. Friction discs or steel discs are worn or warped past specs.
4. New wet clutch not pre-soaked for 24 hours.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
zx 9r net View topic Clutch Slip
http://kawasakiworld.com/zx-12r/42540-clutch-slipping-what-needs-replaced.html
http://serwer.robert.webd.pl:30/manual/Kawasaki_ZX_9R_(ZX900_C1,D1)_98_Service_Manual_ENG.pdf
Kawasaki Ninja Owners Manuals
Feb 10, 2014 | 1999 kawasaki ZX-9R Ninja
1999 Kawasaki ZX-6R Ninja dies when put into first gear
Hi, Dave and the usual suspects are:
1. Faulty wiring to any safety switch.
2. Safety switches loose at the mounting point.
3. Faulty kickstand safety switch.
4. Failed kickstand safety switch circuit diode.
5. Stretched side stand spring.
6. Side stand not coming up far enough to disengage switch.
7. Faulty clutch lever safety switch.
8. Faulty neutral safety switch.
9. Clutch not properly adjusted.
10. Clutch plates sticking, forward lurch
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
ninja will idle but dies when try to put it in gear KawiForums Kawasaki...
zx6r 05 when put in gear engine stalls
Kawasaki Ninja ZX 6R 1995 2002 Service Repair Factory Manual Download... $15
Apr 30, 2013 | 1999 kawasaki ZX-6R Ninja
96 ford wont go into park, drive, or reverse unless in 4 wheel low
Is this a auto or Manual I ask as you say flywheel and all gears. tall us a little more. what is the gearbox ?. have you looked at the oil level and under it at the rear tail shaft, crosses. in 2 wheel drive and running can you get it into park. DON'T try to hard at this as it can damage the auto. If you can drive in 4 wheel low in all gears then it sounds like you may have a problem in the drive line. Tall us more
Jan 07, 2013 | 1996 Ford Explorer
2000 Kawasaki ZX-12R jumps out of gear
Hi, Jhnzzrx and the usual suspects are:
1. Shifter pawl improperly adjusted.
2. Shifter drum improperly adjusted or damaged.
3. Shifter engaging parts/dogs badly worn or rounded.
4. Shifter forks bent.
5. Damaged gears.
Slipping out of gear Kawasaki Forum KawasakiWorld com
http://www.zxforums.com/forums/zx-11-forum/36485-pops-out-2nd-gear.html
Kawasaki Ninja ZX 12R Service Manual
http://mybikemanuals.com/kawasaki
Nov 14, 2010 | 2000 kawasaki ZX-12R
1994 Kawasaki ZX-9R Ninja replace the rear wheel bearings
Hi, Jacob_mccoll for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
How To Change Wheel Bearings On Motorcycle All Balls Wheel Bearing Kit
1986 Ninja 600 Wheel Bearing change
KAWASAKI ZX900 C1 Service Manual
Oct 04, 2010 | 1994 kawasaki ZX-9R Ninja
2000 Mitsubishi Galant 4 cyl ES underhood squeal on right side
The probable causes are: 1. The drive belts are slipping. 2. The drive pulleys for some engine accessories are misaligned. 3. You have turned the steering wheel to the limits. 4. The drive belts are loose.5. Your brake drum backing plates are rubbing against the brake drum. The brakes also might be a problem. check the brake drums/discs. Finally check your wheel and wheel alignment.
May 08, 2010 | 2000 Mitsubishi Galant
2000 Kawasaki ZX-9 R Ninja clicking noise when going into first gear
Hi, Letkeman05 I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH---WHINE
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Cam Chains---CLICKIT
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fenders---SCRAPE
9. Fronk Forks---Plunk
10. Fuel pumps---WHIRR
11. Gears---WHINE
12. Head Gasket---HISS
13. Hydraulic Lifters---TAP
14. Instrument Clusters---BUZZING
15. Kick Starter---GRINDS
16. Pistons---SLAP
17. Power Valves---CLINK& RATTLE
18. Radiators---GURGLE
19. Rear Chains---RATTLE
20. Rear Shocks---SQUEAK
21. Relays---CLICK&BUZZ
22. Shaft Drives---WHIRR
23. Shifting Trans---CLUNK
24. Solid Lifters---TICK
25. Speedometers---bzzz
26. Starters---CLICK
27. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
Clicking noise when take off in first gear ZX Forums
Gearbox CLUNK when goin from neutral to first Kawasaki Forum KawasakiWorld...
Apr 24, 2010 | 2000 kawasaki ZX-9 R Ninja
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
1,012 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
