Question about Samsung TXN3271HF 32" TV
RE: 72034 I need to know how to find the fuse on my tv?
  • 121 Answers
Two fuses one close to line cord entree.  other inpower supply. area. will need ohm meter to ck. is set dead? not many symptons to go on.
Posted on Dec 04, 2008
65hm7 toshiba tv fuse
If ur referring to the 125volt,6.3 amp fuse it is At the rear of tv, where the power cord comes out of tv. U will need to remove the bottom back panel held by +-10 screws(much easier than it sounds) u will see fuse next to where power cord attaches to circuit board. Let me know if that helps or u need pix. Siralosha3@gmail.com
Feb 18, 2014 | Toshiba 65HM167 65" Projection Television
TV turns on then turns off right away
In an answer to your problem, fuse could possibly be good and not blown
basing on your post "
TV turns on then turns off right away "
A fault or two have been detected so the TV will automatically shut off
to prevent further damage.
You will be needing tools, equipment , good vision and a lot of
patience when working with TV.
here is a troubleshooting guide should you need to DIY
Flyback Transformer
• Must have supervision of a qualified service technician
let us know if you need further assistance.
Sep 23, 2012 | Toshiba 32HFX72 32" TV
TV will not turn on. The fuse is blown. Need to
hello,
replace the fuse with the rating of 2.5A,
you can also check the iron head of the fuse.
Good luck...
May 25, 2010 | Televison & Video
Blown fuse inside tv
Look at the fuse you pulled out. The rating is embossed on the side or end.
Dec 28, 2008 | Apex Digital AT2008 20" TV
JVC projection screen with blowen fuse
You have to check the reason , why the fuse blew. It is something else that made the first fuse blow. The fuse has nothing to do with picture after the TV starts up.
Dec 02, 2008 | JVC AV-36260 TV
RE: 72034
dwijackie
TXN3271HF
September 21 2008
You have asked me where the fuse is located
The answer to that is , the fuse is locaed INSIDE THE SET on the chasis.
To find the fuse
1. You will need to look at the back of the television set where the power chord connects to the
chasis, the fuse will be located in that area.
Chasis in this situation means the board wich is located at the bottom of the television
and does not mean the CRT board attached to the picture tube.
Az.
Sep 21, 2008 | Samsung TXN3271HF 32" TV
What size fuse does a RCA PS27113 use?
Where the fuse are put it on the board get the capacity always be 150 volts 5 ampers
Aug 16, 2008 | Proscan PS27113 TV
Rca tv model # F32672SB
The fuse is a 5 amp,can get at any electronics store
Jan 09, 2008 | RCA F32672SB 32" TV
TV Fuse
Most of the time the manuafactirers put the fuse around where the line cord comes into the back of the TV set. are you sure the fuse is bad? Are you thinking the fuse is bad because the TV set will not come on?
Mar 26, 2007 | Durabrand DWT2405 24" TV
TV Fuse
I would think any standard fuse with the same rating would work. If your fuse is blown you also have something shorted in your set. You could try one and if it too blows then you'd need to have it checked out. Stargazer
Samsung TXN3271HF 32" TV Logo
48 people viewed this question
Henry  Thomas
Henry Thomas
