Question about LG WM1814CW Front Load Washer
LG WM1814CW will not turn or drain
  • Anonymous Oct 05, 2008
    I had the same problem. The washer would not drain and the motor would not turn. The display showed LE. I looked it up on the user manual which indicated a motor problem. I thought I was going to have to have an LG service tech come out to replace a fuse or possibly the motor. I cleaned the drain filter at the front bottom left corner of the unit as suggested on the FixYa site. Problem solved. Thank you FixYa!!!!
  • Richard Lew May 11, 2010
    Is there an error code displaying on the readout??
    If not, then you may have a clogged filter at the bottom.  Remove the filter by opening the bottom door on the left corner.  Be aware that there is a lot of water so have some towels ready to soak up the excess water.
I thank you for your support on fixing my OE error. I cleaned out my filter on the bottom left hand corner of my machine. Problem fixed. Be aware that when you unscrew your filter, you may have a lot of water draining.
Posted on Nov 30, 2008
We have an LG WM1814CW washer. For some reason after approx. 10 or 15 min. it will just shut off. Water and soap is still in the drum. The door will unlock and there is no error code. It just quits. We...
Hi tdld6365,
Drain pump may be clogged. Please follow my below tip on the fix:
If this does not help, the drain pump may be faulty.
Kind Regards
* If this solution helped you, please rate it
Sep 11, 2011 | LG WM1814CW Front Load Washer
Where is the drain filter located
If the model is WM1814CW, then the drain filter is located behind the small door located at the left hand corner at the bottom of the appliance's front side.
Aug 08, 2011 | LG WM1814CW Front Load Washer
Spin cycle appears to be broken. washer just hums
Humming can indicate a stalled motor...If a coin is jammed in the pump impeller it will often do what you describe...Check via pump filter access door...Good luck....Nomess
May 08, 2010 | LG WM1814CW Front Load Washer
My LG Tromm WM1814CW is not draining. I cleaned out the drain filter and checked to make sure the drain hose is not kinked and still - there is no water draining from the machine except when I pull out the...
Check inside the filter housing with a flashlite for debris that got around the filter. If it is clean, you have a bad pump and it needs to be replaced.
Jan 26, 2010 | LG WM1814CW Front Load Washer
LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Jul 12, 2009 | LG Washing Machines
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Jul 06, 2009 | LG WM1814CW Front Load Washer
I have an error message on my LG WM1814CW washer The message
This means the machine did not drain within a 10 minute time period. check the pump trap for debris and clean out. Check the drian hose. Check for drain pump operation diring drain period
Mar 06, 2009 | LG WM1814CW Front Load Washer
Lg wm1814cw drain error
Click on LG (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Nov 28, 2007 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
162 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
