Response Yes the wire that comes off the trippler is plugged into the circuit board.
    Novelist:
    Champion:
  • 203 Answers
No picture isnt really something that those ic's can cause so I think we have a wire hooked up wrong, or unpluged. If you send me pictures of the boards inside to my email i will look them over for you.
Tim Nolan
Experttv@comcast.net
Posted on Sep 21, 2008
The circuit board where the battery plugs in not making a good connection and gps wont come, the wiring from car lighter to gps is good , canyou solder wiring to power circuit board.
Hi, yes it's possible you need a soldering iron and 60/40 rosin core solder, remember that soldering iron can make serious burns so be careful, and always work with the device disconnected from any power source.
Nov 13, 2015 | Magellan Car Charger Vehicle Power Adapter...
How do i get my pool heater to come on?
Open the service panel and look on the back of the board for 2 white or yellow wires that plug into it... disconnect it from the board, really wet your thumb with saliva, and touch the two connectors where you pulled the wires off of... and try to fire the heater... If it fires then you know that it is the thermistor.... I will show you a link to the thermistor on our site.... Do you have the minimax NT? if so here is your thermistor PENTAIR Thermistor probe complete 472101
Feb 14, 2015 | Pool & Spa
Robin - now i understand - the controller is up at the handlebars and the wire goes thru the floor and back to the motor - i have no brake controls though - thank you :)
hi, the brake is controlled automatily by the controller, it stops you moving once you released the wig wag and slowed down ....
Regards
Dec 30, 2014 | Pride Go-Go Sport 4-Wheel
My Jandy rs control panel 7751 has gone out?
Yes! Although you the lighting is part of the circuit board, you can order a NEW Circuit Board and install it yourself! Shop around I believe we paid about $375 about a year ago.
The new circuit board should come already pre-wired with a connection plug. Disconnect power to the unit at the breaker. Gently pry off the cover to expose the old circuit board and plug. Gently wiggle the old plug off and attach the new board. I believe there are a couple of screws holding the board in place. The new board should come with instructions as well. If you are at all handy.... save yourself the install fee from the pool tech!
Mar 24, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
SP43R1HL1 MODEL SAMSUNG TV TO HIGH VOLTAGE (EHT) transformer can supply HOW
The "Line Output Transformer" supplies about 8 Thousand Volts at 15.625 KHZ in the UK. The 8KV is passed through a "Voltage Trippler" circuit providing approximately 25KV.
The Trippler uses diode capacitor, diode strap and capacitor filter pump circuit.
Feb 17, 2011 | Televison & Video
No response from any of the four buttons on my jacuzzi pure air. It is getting power because it is going thru the daily one minute purge. Glen
I would check all the wiring to start with. make sure all the cords are plugged into the control box nice and tight.
after that it is a matter of diagnostics.
if the pump is coming to to purge the system it sounds to me like one of the relay's on the circuit board may be out in which case you will need either a new circuit board for the control box if the company sells it separately or a new control box to fix your system.
Feb 08, 2011 | Jacuzzi Home
Treadmill has no electrical response at all...check the outlet and power strip...nothing...any ideas
I suggest checking your power plug then check or reset the circuit breaker on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter plug the unit in and start checking the AC all the way to the lower board and see where the AC is missing.
If the Voltage is good to the board then check DC Out put going the console wire harness should have 5v or 12v DC depending on model if missing then replace lower board if present, then check the continuity of wire harness if bad replace harness. If good upper console needs to be replaced
May 20, 2010 | Proform Sport 1000 Folding Treadmill...
Our Easy-Flo built in vacuum system will not turn off, even when the hose is disconnected. We have to turn it off manually. Could it be a short in one of the wall outlets causing this?
Some models have an on/off switch on the power unit itself. This switch is used to turn your power unit on when you are right at the machine.
If there is no switch on the power unit, unplug your power unit from the wall socket, look for two low voltage wires coming out of the power unit. These two low voltage wires are usually either attached with terminals or are tied to two wires coming out with plastic screw on wire caps. Disconnect the 2 low voltage wires. Plug your power unit back in. If the power unit does not come back on then yes, the problem is most likely a short in the outlet wiring. If the power unit still comes on with the 2 low voltage wires unattached, then the problem is in the internal circuitry of the power unit, usually a relay or some units have a circuit board with relay, circuit breaker and other components on it. The relay or circuit board will have to be replaced.
It's a little difficult to check for a short if you have multiple outlets, but if you've recently done some renovations you might start checking in that area.
May 19, 2010 | Easy Flo EF1400 Central System Vacuum
Swithced ic chips
Those wires are ground wires they don't matter where you hook them up....there is a wire that comes off the trippler (the pice that hangs off the metal that holds the tubes and has the 4 big red wires plugged into it) and plugs into the deflection board is that plugged in?
Sep 20, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
