Question about RCA Lyra M2030 MP3 Player
Wont connect to pc
When I plug it into my PC Windsows xp it flashes RCA and gets to USB connected and then powers off. I can play with it to get it to charge but I can't get it to connect.
This problem just started and I haven't changed anything on my PC.
    Novelist:
  • 116 Answers
Try a new/different USB cable. My Lyra was a painful thing with cables. Also, make sure the plug and receptacle are clean. Improper connection can do this.
Also, you should have gotten a driver CD for the player. It contains the correct drivers for the lyra, and will help Windows XP use the correct USB drivers.
Try those and see what happens. It may just be corrupted USB drivers.
Hope it helps bud!
Posted on Sep 21, 2008
Prestigio multipad 4 diamond 10.1 3g wont charge, but only flashes
Try to connect it to a computer usb and see if it is recognized . Flashing when you push power button means battery is not charged . Flashing all the time when plugged to the power source means it is charging . Try another power cable or check your power input on your multipad - try to move it with toothpick or a pen and see if it is loose or not .
Aug 21, 2016 | Computers & Internet
I have a Sony handycam DCR-TRV 285E. Earlier video file transfer was easy on Windows XP via a USB cable, but after upgrading to Windows 7 the same cannot be done. I am being prompted for an i-link cable,...
jeff_pogi.jpgheres your solution. all you have to do is plug-in the Y-RCA to your handycam and connect it in to USB slot( computer_. it is compatible to Windows XPSP2, Windows Vista and Windows 7. Once you done all connection, open your video recorded and play. theres an all instructions..how to capture your video...copying to your computer. If you to get this email me at jeff_tope@yahoo.com
Feb 17, 2011 | Sony DCR-TRV285E Digital-8 Digital...
Vr5230-acomputer will not recognize my rca voise recorder
if it came with a driver..just run the driver again in the computer and be sure the installation goes OK ..After that restart the PC ..and plug the recorder..it should see it if this was the issue ..Another thing is to plug the device powered and on ..and check the screen of the recorder ..cause sometimes you have to confirm the pc connection ..or ..card reading ..from it ..
If you do not have a driver just check the manufacturer's site..and see if it needs one or it is a plug and play device ..if it is a plug and play ..try to reset the recorder..(look for the reset button in a hole accessible with a stylus or sharp object ) or ..in the menu ..select the reset to factory settings ..
In the last case you will have to reinstall the firmware in the recorder cause it is damaged and not seen by the usb port ..This is the case for those that are plug and play ..and have the driver in the root folder and accidentally deleted..
If it is not damaged or so ..follow these instructions to install the driver built in ..
http://voxrightnow.custhelp.com/app/answers/detail/a_id/10080/session/L3NpZC9xblNKemdraw%3D%3D/kw/vr5230%20driver/r_id/103795/sno/0
anyway ..plug it and check the my computer folder and see if it has a separate drive for its root (may be in the disk drive sections )
Jan 17, 2011 | RCA VR5230 Voice Recorder
Mobile hung on align screen page despite aligning screen several times. mobile was working fine. suddenly system was hung. tried to hard format using call and end button on start up page. ever since the...
Please try this with windows XP
Make sure you:
Turned off any Firewall you have on the PC.
Not running the update in Safe Mode.
Not to perform any other work on your PC.
Make sure the phone is fully charged (important)
Do not update from a PC where you have limited rights. Eg. Internet Cafe, Work etc.
Prefer Laptop as if you have electricity dropped you will have some extra battery and wont harm your phone.
Use only one USB port for you Omnia update, the best one it works for you. Do not try multiple.
Steps used for updating under Windows XP (32 bit).
  1. Make the Install Microsoft ActiveSync 4.5 (once)
  2. Make Install the Samsung Modem Driver XP (once)
  3. http://rapidshare.com/files/179674742/MODEM_DRIVER_FOR_XP.zip
  4. Reboot the PC.
  5. After the first 2 steps try to disconnect your Omnia from USB and connect it back on. Repeat it 1-2 times so the PC can recognize the phone.
    Leave the phone connected for about 10-15 minutes. If it disconnects by itself most probably you have to repeat the procedure from 1st step.
    It is advised to reboot your PC also.
  6. Make sure that have backup all your important stuff (contacts, pictures etc).
  7. Switch OFF the phone by holding the Power button for ~5 seconds.
  8. Run the updater. (Works the same way for Original or Cooked ROMs)
  9. Switch ON the phone again by holding the Power button.
  10. Press START and happy flashing. Do not move your phone or the USB wire as it might fail during flashing.
  11. Wait until the updater shows JOB DONE! DO NOT DISCONNECT BEFORE.
  12. Disconnect your phone.
  13. Leave the phone to reboot 2 times, calibrate screen and finish the start-up procedure.
  14. Enjoy the new firmware.
This is for windows 7 and vista
Things you'll need on Vista:
VMware Workstation (latest will work)
Microsoft Windows XP CD or .ISO image and the serial key
2gb of free disk spaceSafety Tips before starting:
Use the ones that mentioned for Windows XP.
Make sure you turn off the USB on the Windows Mobile Device
Center.How-to disable it. Go to Windows Mobile Device Center:
Mobile Settings -> Connection Settings -> Untick "Allow USB Connections".
After flashing tick it back.Let's start:
  • First install VMware's Workstation. You can get a trial version at http://www.vmware.com/
  • If you have an .ISO image of your Windows XP CD on your hard disk like I do, you won't need the CD, otherwise you'll need it. If you don't have the image, put the CD into your CD/DVD-ROM.
  • Run the workstation.
  • Go to FILE -> NEW -> VIRTUAL MACHINE and choose TYPICAL. On the next tab select the source from where you want to install a virtual Windows XP operating system (CD or image).
  • On the next tab, press next. When the dialog appears, choose YES.
  • Now enter a name for your virtual XP machine and choose a location where you want to save the machine - it's good to have at least 2gb of free space!
  • On the nex tab, I've chosen 2.5gb. I think that's enough, if you wish only to flash your ROM. You can choose to install the machine to a single file or splitted. I've chosen single.
  • On the next tab, click Customize Hardware button and select "USB Controller". Make sure High-Speed USB 2.0 and Auto connect USB devices are checked. Press OK, then press FINISH.
  • Maybe you'll get a warning from VMware but don't bother, just skip it.
  • The Windows installation process should follow. The installation took on my PC for about 25min.
  • When the setup has finished, you can normally run and use Windows XP via WMware.
  • Update your XP machine via Windows Update, reboot and start flashing.
Flashing:
  3. Reboot the PC.
  4. After the first 2 steps try to disconnect your Omnia from USB and connect it back on. Repeat it 1-2 times so the PC can recognize the phone.
  5. Make sure that have backup all your important stuff (contacts, pictures etc).
  6. Switch OFF the phone by holding the Power button for ~5 seconds.
  7. Run the updater. (Works the same way for Original or Cooked ROMs)
  8. Switch ON the phone again by holding the Power button.
  9. Press START and happy flashing. Do not move your phone or the USB wire as it might fail during flashing.
  10. Wait until the updater shows JOB DONE! DO NOT DISCONNECT BEFORE.
  11. Disconnect your phone.
  12. Leave the phone to reboot 2 times, calibrate screen and finish the start-up procedure.
  13. Enjoy the new firmware.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 29, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
I erased all the songs from this mp3 play to put new ones on after erasing the songs the play won't be picked up by pc and am unable to put new songs onto mp3 plaey the players just displays please wait...
yes...unplug from pc shut mp3 off for a minute...plug it to pc (did it come on turn it on)...please get into the habit of disconnecting any usb connection with the safety disconnect...(green icon in task bar when usb is connected)...since you already deleted all files (format it now) start fresh...now you are able to put your songs on it...but to disconnect do not....do not just unplug the usb
Jun 20, 2010 | RCA M2000 MP3 Player
Hi, myself chetna i am having compaq laptop,and the problem is this: whenever i connect my pendrive, my system get hung-up, it stops working, then i abruptly turn off it, and then again start it, somebody...
HP Pavilion dv6000z Notebook
well what can that be , many things
pendrive (a usb port memory stick, and not real DRIVE?)
test it on other pc yet. why not? its failing test it.
many USB mem stick fail due to corrupted files on it.
(removing it incorrectly cause that)
what OS? , you posted with NO OS Stated, at all. XP?
all ports fail on this Laptop?
do other USB sticks fail....>? or USB keyboards, or mice?
the HP OS restore features started about year 2006
called the F11 recovery mode. (that?)
you said.
"but window formatting does not make it work,"
what does that mean, by what means? who done?
using what media or F11 magic key.?
I say the PC is XP? and we all know XP has Horrible
USB support, and NOW worse MS shut down XP servers
for the USB devices, (and more) so will hang when
doing PnP "plug and Pray" driver from there.
XP is DEAD, you do know that right? XP and VISTA are
now DEAD.
recap:
1: the Stick fails on all USB ports.
2: the stick fails in othe PCs
3: running XP and expecting things to work. HAHAHAHAAHAHAAHAHAH (the endless dream?)
my XP works on one PC, but I had to make sure I had all drivers perfect , from each chip maker,
MS and HP dont have them so takes hard work
4: is the Device manager in control panel clear of al errors"
this PC is 10 years old
HP retired it, official
XP is retired at HP and MS.
that PC came new with F11 magic recover key.
the HP manual (covers XP and VISTA )
is still there, will be deleted soon... hint hint..
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
here is DM running and me clicking power tabs
on usb hubs
Sep 13, 2017 | HP Pavilion dv6000z Notebook
No media being played on TV
reformat the hard drive you have lost the fat file and, the display and, audio drivers
May 28, 2009 | Electronics - Others
I am installing a Canon Pixma IP4600. Have plugged in power and USB connection and get alternate green and orange flashes. Followed instructions to disconnect and reconnect the power and usb but to no...
What operating system you have?
If your printer is a USB printer then do the following: First of all please remove the USB Cable from your PC completely. Restart your PC without connecting USB cable back to your PC. Now connect the USB Cable into the USB Jack from both ends and start your PC. Your PC will automatically accept this USB Hardware driver. After doing above steps please reboot your PC finally and Let me know the result, so I can further invastigate the problem.
Scott
Dec 02, 2008 | Office Equipment & Supplies
Dell dimension 2350
if you use a flash light and a magnifying glass all the conection pins will be labeled ;like AUX in, for auxillary in which is usually for usb ports and plug and play items, then there will be a power reset set of pins for the reset button, and LED pins, and then your power should be labeled like wise. some times it wont be but you can look at the connector see if it has 3 or 4 wires and find the plug in that matches that has a u shaped metal place by it. its usually the power connection but if you are not sure take it to a professional so you dont cause damage.
Dec 08, 2007 | Dell Dimension 2350 PC Desktop
My XP Media Center PC does not recognise the scanner
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port? You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC. If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
Oct 16, 2006 | Symbol CS1504 Handheld Barcode Scanner
RCA Lyra M2030 MP3 Player Logo
53 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
