Question about Philips 42PFL5332D 42 in. LCD Television
TV COLOR THE COLOR IS OFF WHEN I PLAY A DVD ON MY NEW PHILIPS TV - I TRIED ADJUSTING WITH LITTLE RESULTS. COULD MY DVD/TV CONNECTIONS BE INCORRECT?
  • 26 Answers
Your DVD is set to have S-video output (or composite NTSC or PAL - switch to tv norm that is used in your country or use SCART cable and set dvd output to RGB
hope this helps.
Posted on Dec 11, 2008
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play...
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Mar 23, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
Incorrect color when playing DVD
Hello Mustang Cathy,
You have connection problem in Video with TV & Home Theater. This error comes mostly wrong combination of "Component Video" connections. Kindly check that one color pin must be connected with same color pin at other unit. Here is 2 pictures for further assistance. Hope problem will be solved and you will enjoy true color picture on tv.
Apr 07, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Tv is in color but when you put dvd in then it is black and white
You have the connections on either the TV or DVD hooked up incorrectly, check your cables to make sure they are in the right places.
Jun 17, 2010 | Philips Magnavox DVD/VCR Dual Player
I do not get color on the TV
If you are using the S-Video output, please try a different cable or first re-seat the connections at both ends.
Good luck
Jan 04, 2010 | Philips DVP320 DVD Player
Bad DVD picture
please reset the factory seetings in uer dvd player, throgh menu button on uer remote. Firstly open uer tray and after take rhe menu and select factory reset, and reset it,
Mar 02, 2009 | Philips DVP5140 DVD Player
Can't adjust color
Its connection combination problem of " component video " You have selected/ connected wrong pins with other unit. Always insert same color pin on both unit (TV & DVD player)
Have nice day!
Jul 20, 2008 | Panasonic SC-HT700 System
Color problem
CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Sony DVD player color adjustment (Model #DVP-N5400D)
Solved the problem!Well, After reading two manuals on the Sony DVD player, I saw one cable not connected: the S Video connection. I connected that. Tried it out again, seemed a little better, but still not the full range of reds. At that point I thought the problem was either: 1) the cables from the DVD player to the TV or 2) the DVD player is the problem So, I thought I'd start with replacing the cables. Labeled them as to where they went, took them out and went to Radio Shack and explained my problem. The clerk I spoke to was very nice, said he had seen this problem before, and said there was a menu on the DVD for adjusting RGB settings.
So, I went back home, plugged in the cable, and went all thru the 2 Sony DVD booklets and the display menu on the TV. There was nothing mentioned re: color settings. Went thru the DVD menu many times, looking, looking. I felt I had come up with nothing.
Turned everything off. Turned back on. Put in a DVD: It looks great! :)
So, hoping it never happens again..cause I'm not sure I can repeat it! Maybe it was removing all the cables from their sockets and restarting...I know that sometimes works with computers...anyway.. At least I didn't have to buy a new DVD! Lesson: unplug, re:plug...before you trash it!
M~
Mar 06, 2008 | Televison & Video
Philips lcd flat 32 in
what cable are uusing for dvd yello thats why cant use yello on these or s video go buy hdmi cable ok or reg green blue if dvd dont have hdmi outs
Feb 09, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
Philips 42PFL5332D 42 in. LCD Television Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
